dj4uk Posted February 28, 2007 Report Share Posted February 28, 2007 I've got an Audi A3 2.0 FSI (03 reg) and it seems to smoke more than I expected - the smoke is white and worse when the engine is cold - seems to disappear when up to temp. Only had this car since Jan and the dealer says it's normal. I had a head gasket go on a car in the past so I may be being paranoid - oil looks ok not going brown and lumpy. Any A3 owners confirm this is normal? Is there anway I can test it isn't a gasket problem? Cheers DJ Link to comment Share on other sites More sharing options...
PetrolDave Posted February 28, 2007 Report Share Posted February 28, 2007 Are you sure it's smoke and not water vapour? Link to comment Share on other sites More sharing options...
dj4uk Posted March 1, 2007 Author Report Share Posted March 1, 2007 No it could be water vapour - I've only had the car since the beginning of jan so it's been cold. But to be honest there seems to be a lot of it if I compare to other cars I've had. Link to comment Share on other sites More sharing options...
PetrolDave Posted March 1, 2007 Report Share Posted March 1, 2007 The exhaust gases of the FSI are colder than normal so there will be more water vapour on cold damp days - you should see the cloud behind my RS4 on a cold damp day! Link to comment Share on other sites More sharing options...
harddrive Posted March 10, 2007 Report Share Posted March 10, 2007 I think I remember reading somewhere that this can be caused by clogged injectors. This is normally cleared by adding an additive to the fuel that will clean them on the way through the engine. See here Link to comment Share on other sites More sharing options...
