A6 Loosing Coolant
moggle
I have a 2004 model A6 1.9TDI, which has started to loose coolant. I first noticed when the dash warning symbol was displayed. The resevoir was almost empty when I checked. I topped up with distilled water and booked in to the local Audi garage.
Is coolant leaking a typical problem for the A6? Are there any hoses or other items that could be a problem? The car is almost out of warranty and if problems persist I may look to change.
Thanks
Had a similar issue and turned out to be a very minor fracture in the plastic header tank, at the base. You could 'smell' the hot collant hitting a hot manifold but could only see if it you stuck your head in an awkward position.....
Fortunately it was under warranty - although not a particularly difficult item to change by all accounts. IIRC it was mentioned as a 'not uncommon problem'.
