tyres for s8 - do i need XLs???
gngillespie
I've had to change 3 of my tyres as they've gone "egg-shaped" (?"pear-shaped"??!) and are causing a faint vibration, mind you, thought it was bearings, so that's a relief! Not particularly worn, mind u... confused.gif
I have standard 8jx18 Avus alloys, with the 245/45s on them, and was wondering if the problem could be prevented from happening again with extra load tyres... don't know what pro's and cons are, although i'm sure a harsher ride with XLs
should the S8 NEED XLs???
cheers
ive always ran goodyears and pirelli rubber,when changing tyres on your S8 you must change all four tyres together so the wear rate is the same and every 1k i change the rears to the front due to the wait of the engine causing extra wear,if the tread wear is different and uneven it can cause diff problems because the wheels are not rotating at the same speed.the quads are done ive posted some pics thanks 169144-ok.gif
i put 4 contisportcontact3's on mine for the MOT last year & they've been pretty good so far 169144-ok.gif
i fitted the XL rated tyres
fair bit quieter than the Pirellis i had on there before & seem to have been pretty solid in a couple of situations that looked like i'd be aquaplaning EEK2.GIF
edited for typo
