Correct order for bleeding brakes??
GTR32
To quote from the Bentley manual
Bleeding sequence
1 - Right rear caliper
2 - Left rear caliper
3 - Right front caliper
4 - Left front caliper
BUT
When at least one chamber in the
brake fluid reservoir is completely
empty (e.g. leaks in braking system)
the hydraulic unit must be bled with
scan tool VAG 1551 in function
"basic setting".
I think basically you have to use Vagcom to operate the ABS pump to remove the air from it.
The rule for bleeding the brakes on any car is to do the one furthest away from the master cylinder first, working towards the closest. The Bentley manual is written for left hand drive cars (where the master cylinder is on the left, in front of the driver, hence the order, so you should really do rear nearside, rear offside, front nearside, front offside.
The information posted above is incorrect.
The MkIV R32 has the ITT Mark 60 IE ABS system and
Bentley says that the bleed order for that is
Left front
Right front
Left rear
Right rear.
Basically nearest to farthest.
The bleed order posted earlier is for the ITT Mark 20 IE System.
ian
I've also read that the R32 must be bled from
NEAREST to FURTHEST,
So on our UK cars, that means,
Drivers Front
Passenger Front
Drivers Rear
Passenger Rear
I followed a detailed guide when I did mine, which I'll post up later.
I bought a 1 litre can of Oil from VW, and found that I actually had more than enough oil to do the 4 calipers.
so I by the time I did the last brake caliper, and I went round and re-bled the front driver's brake caliper
http://www.billswebspace.com/R32BrakeandClutchPressureBleedingProcedureBYAnthony.pdf
Thats the link that I used for information.
Taken from a link on bill's R32 website
Pls take note, because american cars are LHD, they say bleed from front left first.
UK cars need to be bleed from front RIGHT first! (becuase the master cylinder is always on the drivers side!)
Basically rule of thumb with R32 is, bleed closest to farthest
Left front
Right front
Left rear
Right rear.
ian
Just to reply to Ian,
UK car's being RHD, the master cylinder is also on the Right (not the left like in USA cars), so the order is right, left, right, left
Thanks guys.
I had read the artical on BILLSWEBSAPCE by Anthony and actually got hold of him in hope that he would know for sure....he didn't. Logic would say, for a RHD car, to do it like Gti Fly says - right, left, right, left moving from front to back.
Does anyone know for sure?
Does it really make any difference?
I have never seen a Bently manual - is there not one for RHD cars or is it a US only thing?
Yeh VW Dot4 brake fluid.
The old fluid that came out was brownish in colour (only a year old), and the new fluid was a very very clear yellow.
Other than that, there was no sign of air bubbles, but did see small floating bits of debris.
Glad I changed the fluid
Don’t know if you just intend to flush the system or actually drain it and do some work, but I fitted stainless braided lines and replaced all the rubber one's on my Mk4 some time ago + replaced with race fluid
After you have done the 4 callipers’ there is then a 5th nipple on the master cylinder, this is quite hard to get to but if you don’t do that one also you will never get full brake pressure back into the system.
cheers
Matt
