samsung p300 and RNS-E
i had the RNS-E and Bluetooth upgrade done yesterday which is such an improvment, but the only issue i have, is when i go to make a call by only using the RNS-E as in using the dial, it tries to connect then instantly ends call without connecting, but if you dial it by using the handset its connects fine, I`ve tried it on a motorola v3 which works fine by only using the the dial.
was wondering if any else has a Samsung p300 and RNS-E and had the same issue??
