anti rollbar swap.... fitting guide ?
bmx
The rear one is really very simple on the GTI. I had my car up on some ramps for an oil/filter change and it's all out in the open. Just six nuts/bolts and the rear one is off no problems.
The front one, whilst I couldn't get a good look at it looks more involved. From what I could see, and this might be incorrect, that the Anti-roll bar bolts onto the top of the front subframe in what looked to be a tight area. Not sure if you'ld need to drop the subframe though. You might be able to unbolt it and pull it out the fromthe front wheel arch but I just can't say for sure.
Hope that helps.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
