[Audi A3/S3] Redex/Additive
R4V_S3
Just use good fuel. Ie V Power from Shell.
I was warned off fuel additives by my tuner (specifically Millers Octane booster) as it can cause combustion to burn hotter, which could be detrimental to items such as spark plugs etc.
Tesco 99 is fine also to use mate. Reading through EVO, they also rate BP Ultimate, but it's only 97 Ron, whereas on the inside of your filler cap, Audi reccommend a minimum of 98 Ron for the S3.
As the others say, don't both with fuel additives. Just stick with Shell or Tesco 99 if you can't use V Power. 169144-ok.gif
The car is only designed to run on 98 ron putting 102ron in will have very little effect as the map just isnt designed to use it. An import jap car on the other hand thats mapped for 101ron(i think that the number anyway) will see the benefit but you will pay for it.
Audi's should cope to a degree with the knock sensors and advance the timing to suit. But it will take a tankful or two to adapt to it.
I agree but they are still only mapped for up to 98ron. They will run fine on higher ron fuel but will see no benefit llfrom it at all. Turbo cars will advance the timing but limit the boost, so you see no gain unless they are mapped correctly.
