S4teve Posted May 5, 2007 Report Share Posted May 5, 2007 I changed my front brake pads a couple of months back (1000 miles ago) and today the brake pad warning indicator on the DIS keeps coming on. I'm thinking that perhaps one of the sensor cables / connectors may be loose / damaged?? Do the rear pads also have wear sensors? If so these may also be worn but I thought only the fronts had the sensors. Any thoughts / advice??? Link to comment Share on other sites More sharing options...
Sparky Posted May 6, 2007 Report Share Posted May 6, 2007 Only the front pads have a sensor on the inside pad, so perhaps a cable has come off or the sensor is damaged? Link to comment Share on other sites More sharing options...
