lwj983 Posted June 9, 2007 Report Share Posted June 9, 2007 Posted in the tech thread but not many people on there, anyone know if it has an 'in line fuse'? : Hardly a major problem but any help/ideas would be appreciated. The cigarette lighter socket in the front of my Mk4 Golf has stopped working, checked the fuse in the fuse box in the dash board (by drivers door) which is fine. I need it working for sat nav so currently using an extension through the car from the boot socket. If its totally blown and needs replacing how much do your reckon a stealer will charge? I think it must have stopped working when I had a flat battery (left lights on.....opps) and tried to use one of those cigarette lighter jump lead things..........which didn't work, must have b*ggered it up some how. That's what I get for being lazy and not getting the jump leads out! Cheers Link to comment Share on other sites More sharing options...
jedster0 Posted June 9, 2007 Report Share Posted June 9, 2007 If fuse F35 in the fuse box is ok then it could be dity contacts in the lighter itself (dont try and clean it with the fuse in place). If thats not it changing the lighter is not hard, you can do it yourself if you have the correct size Torx bit Link to comment Share on other sites More sharing options...
Wobby Posted June 10, 2007 Report Share Posted June 10, 2007 [ QUOTE ] I think it must have stopped working when I had a flat battery (left lights on.....opps) and tried to use one of those cigarette lighter jump lead things.......... [/ QUOTE ] Do these exist!? Is this used to recharge the battery a bit? Not to try and start the engine with? Sounds worrying to me Link to comment Share on other sites More sharing options...
jedster0 Posted June 10, 2007 Report Share Posted June 10, 2007 [ QUOTE ] Do these exist!? Is this used to recharge the battery a bit? Not to try and start the engine with? Sounds worrying to me [/ QUOTE ] They do exist. they go from the cigarette lighter of one care to another, but are nowhere near as good as a good ols set of heavy duty jump leads http://cgi.ebay.co.uk/Easy-Start-Clean-H...1QQcmdZViewItem Link to comment Share on other sites More sharing options...
lwj983 Posted June 15, 2007 Author Report Share Posted June 15, 2007 Cheers for the help fellas. I've bought an extension cable to run from the boot socket to the front has a temporary fix, only £5 from Maplin....bargain. I'm preety certain the actual socket has died. I'll use the extension until I decide if to change my car, tempted by an Octavia vRS (old shape). Any views on these? Link to comment Share on other sites More sharing options...
