pritesh Posted July 26, 2007 Report Share Posted July 26, 2007 Hi all, Question: My engine management light came on a few weeks ago...I got the fault code out and it said to me "system too Lean"..I traced the problem to a split vacum pipe which escaping air. Having fixed the pipe...a day later the engine Management light cancelled it self... Has anyone seen this happen before? cheers P Link to comment Share on other sites More sharing options...
Rustynuts Posted July 26, 2007 Report Share Posted July 26, 2007 Yes the light does go out when it senses the problem is fixed, but it still stores the fault code in the memory. That can be removed next time you have it serviced or hooked up to VagCom. Link to comment Share on other sites More sharing options...
