alcatraz Posted August 1, 2007 Report Share Posted August 1, 2007 Right then, not sure how to describe this one, I get in my car, turn the key to the helf way point so the lights go out, on doing this I hear noise eminating from the area of the fuel tank or drivers side rear wheel, sounds a bit like a hissing noise, or someone going 'pssst', it only lasts for around 2 seconds. Turn the key back and try it again and the noise is there, but this time, only lasts for a split second, third time trying, no noise at all, which makes me think something is readying it self for movement or warming up. Turn the engine over and then off again and we go through this all again...very odd. Was going to take it to garage, but thought tyresmoke would be a good place to start! Link to comment Share on other sites More sharing options...
activa Posted August 1, 2007 Report Share Posted August 1, 2007 I got a feeling this is the fuel pump priming itself. Don't think it's anything to worry about,my Golf has done it since the day I got it and never caused a problem. Link to comment Share on other sites More sharing options...
alcatraz Posted August 1, 2007 Author Report Share Posted August 1, 2007 Yes, it does sound like it could be that, I just have not noticed it before. Cheers. Link to comment Share on other sites More sharing options...
daveCh Posted September 26, 2007 Report Share Posted September 26, 2007 my passat 130 01 used to do it. turn key on a second or so after it makes the noise like a shweerp sound. never a problem with it. now got golf it dus it as well. Link to comment Share on other sites More sharing options...
speaky Posted September 27, 2007 Report Share Posted September 27, 2007 I concur with SootChucker. Most likely the fuel pump priming itself prior to ignition. Guess that's why the advice re miss-fueling is to NOT turn the ignition key at all, cos (admittedly a small amount of) the wrong fuel will be sucked into the pump and therefore get to the engine etc Link to comment Share on other sites More sharing options...
alcatraz Posted October 4, 2007 Author Report Share Posted October 4, 2007 Yep, the noise stops when tank is filled, and then come again again when about 3/4 empty. Link to comment Share on other sites More sharing options...
