MACH1 Posted April 6, 2006 Report Share Posted April 6, 2006 Anyone know why my engine management light is on? I have plugged the vag tester in and no fault recognised, So i turn the light off, it stays off for a few days then returns, car appears to be running smoothly so i am completly at a loss as to what it is, any help much appreciated. Also i have a small oil leak from the rocker cover at the very back of the engine, I have had it changed but i still have a small leak, any Ideas please. Link to comment Share on other sites More sharing options...
Dave Posted April 6, 2006 Report Share Posted April 6, 2006 If your engine is burning oil then this will be picked up by the sensor (lambda?) in the exhaust and give you that message. Link to comment Share on other sites More sharing options...
Stoogie Posted April 6, 2006 Report Share Posted April 6, 2006 [ QUOTE ] Anyone know why my engine management light is on? I have plugged the vag tester in and no fault recognised, So i turn the light off, it stays off for a few days then returns, car appears to be running smoothly so i am completly at a loss as to what it is, any help much appreciated. Also i have a small oil leak from the rocker cover at the very back of the engine, I have had it changed but i still have a small leak, any Ideas please. [/ QUOTE ] my light came on due to a very small split in one of the pipes. it ran perfect other wise. Took the guys a while to find and it was very small. hope this helps Link to comment Share on other sites More sharing options...
MACH1 Posted April 6, 2006 Author Report Share Posted April 6, 2006 No cars not burning oil just a leak from somewhere on the back of the engine! Link to comment Share on other sites More sharing options...
MACH1 Posted April 6, 2006 Author Report Share Posted April 6, 2006 What pipe? where abouts on the engine please. Thanks. Link to comment Share on other sites More sharing options...
DanRS Posted April 7, 2006 Report Share Posted April 7, 2006 Has an intermitant Engine management light on our 2.7t allroad... ended up being the lambda sensors themselves. Had 'em replaced been fine since. Thing is I think the generic engine management means it can potentially be lots of things. XFS Link to comment Share on other sites More sharing options...
DanG Posted April 12, 2006 Report Share Posted April 12, 2006 Engine Management Light can also come on if your fuel cap is not done up tightly... It can mean thousands of things. Could the leak be dropping oil presure perhaps? although I suppose you would get a code for that.... Lambda sensors would show a code too.. Are you getting absolutly no codes?? Link to comment Share on other sites More sharing options...
MACH1 Posted April 16, 2006 Author Report Share Posted April 16, 2006 No I'm getting no fault codes at all! I think I'm going to have to take the car into the Main Dealers to get it checked out, This is going to cost me I think. [ QUOTE ] Engine Management Light can also come on if your fuel cap is not done up tightly... It can mean thousands of things. Could the leak be dropping oil presure perhaps? although I suppose you would get a code for that.... Lambda sensors would show a code too.. Are you getting absolutly no codes?? [/ QUOTE ] Link to comment Share on other sites More sharing options...
