S3ENVY Posted October 1, 2007 Report Share Posted October 1, 2007 I've noticed that certain MP3's will not play from the SD slots on my RNS-E unit & wondered if anyone else has had the same experience? The names show up on the screen but it will skip the tracks to the next ones playable. They're definitely not WMA's or any other format, so I was wondering what defines an MP3 file that the unit can play? Link to comment Share on other sites More sharing options...
Paulstevo Posted October 2, 2007 Report Share Posted October 2, 2007 Take it your disks are decent qual.. Skipping usually results from bad burn,bad media,failing head unit..Thats only on previous head units i have had that were non audi..try different burning program,or diff media... Link to comment Share on other sites More sharing options...
S3ENVY Posted October 2, 2007 Author Report Share Posted October 2, 2007 Hey buddy, They're not actually CD's, it's the SD card slots that I'm playing the MP3's from. The unit will show the file name on the screen, however when you attempt to play the file it will skip to the next playable one. Link to comment Share on other sites More sharing options...
techieboy Posted October 2, 2007 Report Share Posted October 2, 2007 Non-alphanumeric characters in the filename? I'm sure I read RNS-E didn't like strange characters in the filename or similar. I've not encountered the problem on my RNS-E (or at least haven't noticed). Link to comment Share on other sites More sharing options...
S3ENVY Posted October 2, 2007 Author Report Share Posted October 2, 2007 A-ha, that could well be the problem! Cheers guys, I will have a go at renaming the files this evening & re-try it! Link to comment Share on other sites More sharing options...
Cupramax Posted October 2, 2007 Report Share Posted October 2, 2007 Yep, remove anything from the file name thats not a letter of the alphabet including hyphens & apostrophes. Link to comment Share on other sites More sharing options...
S3ENVY Posted October 2, 2007 Author Report Share Posted October 2, 2007 Cool, will give that a go! Link to comment Share on other sites More sharing options...
PetrolDave Posted October 2, 2007 Report Share Posted October 2, 2007 If you have EU SW version 0550 or 0600 the "illegal" character restriction has been removed. The other situation I've seen cause this problem is where the ID tag has a format that the RNS-E cannot read (it's not 100% compliant). This happened to me when I ripped the audio from a DVD. To solve it I opened the file with a tag editor, deeleted the old ID tag and created a new one. Link to comment Share on other sites More sharing options...
johnny11 Posted October 2, 2007 Report Share Posted October 2, 2007 i`ve had it before when the RNS-E will not play certain mp3`s , on the sd card, but when put into my pc card slot all ok, what i did was load the mp3 into cd to mp3 ripper program and redo the mp3 to the same bitrate, then save, reload to sd card and then in my case works in the RNS-E Link to comment Share on other sites More sharing options...
PetrolDave Posted October 2, 2007 Report Share Posted October 2, 2007 [ QUOTE ] i`ve had it before when the RNS-E will not play certain mp3`s , on the sd card, but when put into my pc card slot all ok, what i did was load the mp3 into cd to mp3 ripper program and redo the mp3 to the same bitrate, then save, reload to sd card and then in my case works in the RNS-E [/ QUOTE ] That will have had two effects: 1) re-making the MP3 ID tag; and 2) possibly changing the codec used. I still reckon it's an ID tag problem. Link to comment Share on other sites More sharing options...
Chav Posted October 3, 2007 Report Share Posted October 3, 2007 i've had this a couple of times - on files that SHOULD play. eg < 64 characters, all alpha-numeric etc. the name displays fine, but it just skips the song. last song to do it was fergie big girls dont cry. havent worked out why yet. bizarre! its 192kbps which should be fine. its definitely not a tag problem! Link to comment Share on other sites More sharing options...
PetrolDave Posted October 4, 2007 Report Share Posted October 4, 2007 [ QUOTE ] i've had this a couple of times - on files that SHOULD play. eg < 64 characters, all alpha-numeric etc. the name displays fine, but it just skips the song. last song to do it was fergie big girls dont cry. havent worked out why yet. bizarre! its 192kbps which should be fine. its definitely not a tag problem! [/ QUOTE ] Most likely a codec problem then. Link to comment Share on other sites More sharing options...
