High revs, engine warning light on 1.8T
Motormouth
Is it revving over 1500 RPM and only for a few seconds then dropping back to idle at 700 or so RPM, or is it running at about 1,000 rpm for a couple of minutes on startup? If so, it's nothing to worry about.
Re the engine warning light coming up, it can be lots of things unfortunatlely - it's just Audi can't output enough data on the dash to tell you exactly which component it bitching. Best thing to do is to find someone with a VAG-COm to plug it in and tell you what the error is, or your local independent Audi specialist, or your local Audi dealer.
  • 2 weeks later...
