gunner Posted January 20, 2008 Report Share Posted January 20, 2008 When my TT was serviced 5000 miles ago, it was filled with Mobil 1 5w30 esp, this is vw 503.01 compliant so is the correct spec for the car which has been re mapped and now produces around 270 bhp. A couple of times I have noticed the oil was low and have purchased a litre of Mobil 1 0w40 thinking it was the right spec. After filling, I have then noticed the spec is 502.00 and 505.00 but not 503.01. The next service is due in 5000 miles, should I just wait until then for an oil change with the correct spec or should I get it changed immediately? There is probably around 1.5 litres of the wrong oil in the sump. Link to comment Share on other sites More sharing options...
Scotty Posted January 20, 2008 Report Share Posted January 20, 2008 Since you're pushing the tolerances closer by it being remapped anyway, I wouldn't take the risk. For the cost of an oil change it doesn't seem worth it. Link to comment Share on other sites More sharing options...
Kaskat Posted January 20, 2008 Report Share Posted January 20, 2008 Get a Pela 6000 oil pump (£35) and suck the oil out from the dip stick tube, take around 10 mins total time, oil is relativly cheap in conparison to buying a new engine. the oil that you have mistakenly put in your engine will be a different viscosity at a certain temperature, my advice would be to change it asap. Link to comment Share on other sites More sharing options...
