MERV Posted February 22, 2008 Report Share Posted February 22, 2008 Hi all Have a gt tdi golf 115hp with a 130hp head on it and it seems to have a lack of power after 2500rpm does anybody have any ideas as to what would be wrong thanks merv Link to comment Share on other sites More sharing options...
Mook Posted February 24, 2008 Report Share Posted February 24, 2008 It's more than likely to be the MAF sensor (a.k.a. Mass Air Flow Meter). This measures the volume of air being drawn in and adjusts the fuelling accordingly. They're a really common problem on most every VW. They cost about £80 to replace and this is a 5 minute job (although you'll doubtless be charged an hour by your VW garage or specialist). One other, less likely cause is one of the air pipes springing a leak. Happened on Mrs Mook's GT TDI. HTH Link to comment Share on other sites More sharing options...
TaxBBbuick Posted February 25, 2008 Report Share Posted February 25, 2008 Is this a recent problem? I am seeing the same thing with my jetta tdi i saw a thred posted back in 07 that went over this issue Link to comment Share on other sites More sharing options...
Mook Posted February 25, 2008 Report Share Posted February 25, 2008 No. It's been a problem ever since VW introduced the 1.8T and the 1.9TDI way back in the late 90s. Link to comment Share on other sites More sharing options...
MERV Posted February 27, 2008 Author Report Share Posted February 27, 2008 Thanks for that but I changed the air mass metre a fortnight ago and it made no difference. What air pipes do you think would be leaking or would it maybe be a vacumn pipe??????? Thanks Merv Link to comment Share on other sites More sharing options...
MERV Posted February 27, 2008 Author Report Share Posted February 27, 2008 Yes I haven't got the car that long because when I got her I had to replace the head so I don't know what is wrong but it is doing my head in Thanks Merv Link to comment Share on other sites More sharing options...
MERV Posted February 27, 2008 Author Report Share Posted February 27, 2008 Yes this problem is just a recent one because when I got the car I had to change the head on the car. Link to comment Share on other sites More sharing options...
Mook Posted February 27, 2008 Report Share Posted February 27, 2008 Any one of the pipes in between the air intake and the manifold - if there's any leak at all, the pressurised air will be leaking out and your turbo will be wasting its breath. Link to comment Share on other sites More sharing options...
MERV Posted February 27, 2008 Author Report Share Posted February 27, 2008 Thanks for that I will maybe give it a try later.Would that leave her hard to start from cold as well.?? Link to comment Share on other sites More sharing options...
Mook Posted February 27, 2008 Report Share Posted February 27, 2008 No, because you don't need the turbo spooled up to start the car. Do you have problems starting from cold? Link to comment Share on other sites More sharing options...
MERV Posted March 1, 2008 Author Report Share Posted March 1, 2008 Yes very much so but when she gets the initial start over she is ok Link to comment Share on other sites More sharing options...
