surfdude Posted April 4, 2008 Report Share Posted April 4, 2008 Just traded my 2006 320d for an ex-demo 335d Coupe M Sport with 3k on the clock. Had it a week and it seems as quick as my 2005 M3 Conv - stunning! It has good a good spec, but no BT prep. Anyone had the BMW kit retro fitted, maybe by an independant ? Thanks Link to comment Share on other sites More sharing options...
gizze Posted April 8, 2008 Report Share Posted April 8, 2008 Have you got the logic 7 sound, nav or DAB radio? if you have I think it is quite an easy retrofit. Link to comment Share on other sites More sharing options...
surfdude Posted April 9, 2008 Author Report Share Posted April 9, 2008 No, just got the standard radio with single CD. No NAV. Link to comment Share on other sites More sharing options...
gizze Posted April 10, 2008 Report Share Posted April 10, 2008 The problem with the new kit is it uses the most bus (optical network) to hook up, and only cars with either, nav or with dab, logic7 or bluetooth need the harness with the optical cable. if you have the Professional radio there is a slim chance you do have it though, have a look in the boot behind the trim panel on the left, see if you can see a cable there. Have you got a cd changer? Link to comment Share on other sites More sharing options...
surfdude Posted April 16, 2008 Author Report Share Posted April 16, 2008 thanks gizze, will take a look when i get the car back. It has packed up twice ! Not happy at all .... stuck in park, garage fixed it, then stuck in third gear, then in park again !!! Hope to get it back some time this week, then will look for cable. I know it does not have a cd changer.. Link to comment Share on other sites More sharing options...
gizze Posted April 19, 2008 Report Share Posted April 19, 2008 Tell your dealer to look at this service bulletin for bluetooth retrofit. http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B841405g.htm Which links to this retrofit guide.... http://www.bmwtis.com/tsb/attachments/B841405_E9x.pdf You could get all the bits yourself, fit and then get the dealer to programme the car, this would be far, far cheaper. Link to comment Share on other sites More sharing options...
gizze Posted April 21, 2008 Report Share Posted April 21, 2008 http://www.bimmernav.com/BMW_new_Bluetooth_Installation_Instructions.html All the parts needed, brand new for £400. Link to comment Share on other sites More sharing options...
