Whats that Tape?
NOBLEDRIVER
Il have a stab at this, someone will be along shortly to fix my mess, but im guessing your talking about the 3M masking tape that the guys use whilst doing paint correction, and if i'm not wrong (which I will be) its because they need to mask off areas that are likely to be burnt when using the PC machine as well as window seals and anything that's not part of the paintwork.
EDIT: looks like me and luke have the same idea.
It's 3m 3434 tape. It's low tack tape, so doesn't leave a sticky residue behind.
With a machine polisher you can do a few very bad things, that the tape prevents. Firstly, you can catch plastic trim with the pad, and it will flash white. Sometimes this can never be fixed. Secondly, if there's thinning near a panel edge, you can burn through. And thirdly, you can burn through plastics, or bubble the paint on plastics (door handles etc.) That's why we make sure areas are taped up as this almost 100% prevents this from happening.
