bigface Posted August 28, 2008 Report Share Posted August 28, 2008 A fella i work with has just traded in his xf for an M3 4 door. It has the 7 speed paddle box so i was wondering would this be able to do the launch control take off that his M5 would have done? If so how would it be done as i wouldnt mind a rattle at it tomorrow!! MOK Link to comment Share on other sites More sharing options...
tom_hargreaves Posted August 29, 2008 Report Share Posted August 29, 2008 (edited) If I remember correctly, when the car is in Drive, you push and hold the gearshifter forward. After about 3 seconds a little chequered flag appears in the temperature display between the Rev Counter and Speedo. Still holding the gearshifter forward, floor the throttle. The engine will rev and hold at about 5,500rpm. When the engine is holding the revs, release the gearshifter. The clutch will bang in and you'll be off. But be careful with this if you've never used it before, there's a load of wheelspin and you'll need to be quick to get your left hand back on to the steering wheel to keep the car in a straight line. I wouldn't recommend this on a normal A road where it's busy or if it's wet. Just remembered, you'll need to be in M Drive aswell. Edited August 29, 2008 by tom_hargreaves Link to comment Share on other sites More sharing options...
bigface Posted August 29, 2008 Author Report Share Posted August 29, 2008 I tried it in the M5 and it was awkward enough on a dry road but fun none the less cheers ill see if i get it working Link to comment Share on other sites More sharing options...
tom_hargreaves Posted August 29, 2008 Report Share Posted August 29, 2008 I tried it in the M5 and it was awkward enough on a dry road but fun none the less It works in the exact same way as the M5, so just use it the same. Link to comment Share on other sites More sharing options...
Elliot Posted August 29, 2008 Report Share Posted August 29, 2008 But be careful with this if you've never used it before, there's a load of wheelspin Really? Would be really unusual for LC to produce loads of wheel-spin, as the main purpose of it is to give a controlled launch (hence the name!). On my CSL it allows minimal wheel-spin. It uses the clutch (pulses it) to limit wheel-spin and maintain forward drive. Not tried the E92 M3 DCT but can't see why it would be much different (?) Link to comment Share on other sites More sharing options...
Woppum Posted September 1, 2008 Report Share Posted September 1, 2008 It does tend to depend on weather and surface conditions though elliot. try it in the damp with cold tyres and a fair amount of wheelspin is easy. Try it with Warm cups on high surface tarmack and there is next to none. Then there is that bit in the middle Link to comment Share on other sites More sharing options...
tom_hargreaves Posted September 3, 2008 Report Share Posted September 3, 2008 Really? Would be really unusual for LC to produce loads of wheel-spin, as the main purpose of it is to give a controlled launch (hence the name!). On my CSL it allows minimal wheel-spin. It uses the clutch (pulses it) to limit wheel-spin and maintain forward drive. Also in comparison, there's 507bhp going to the back wheels as opposed to 360bhp in your CSL. It's easy to spin the back wheels in dry weather aswell. I personally found doing it myself achieved the fastest acceleration. Although what Wopp has said would probably be the time to exploit it to its full potential. Link to comment Share on other sites More sharing options...
