nooptions Posted November 27, 2008 Report Share Posted November 27, 2008 Hi there. Tearing what little hair I have out over this... Trying to get the above adaptor to work with the factory fitted chorus (May 2008). Bought the wrong adaptor initially (plugs wouldn't fit in holes on back of chorus ), then the "right" one - attached the earth lead, plugged the connector into the CD changer socket and pressed the "CD" button on the chorus twice to switch to CD changer input ........... nothing happens. Any thoughts greatly appreciated I should mention the car didn't come with a CD changer although I understand from those who know more about these things than me that shouldn't matter. Link to comment Share on other sites More sharing options...
Mook Posted November 27, 2008 Report Share Posted November 27, 2008 Never heard of the Connects2 product. Have you tried the manufacturer's web site to see if they have ny online help? Link to comment Share on other sites More sharing options...
nooptions Posted November 27, 2008 Author Report Share Posted November 27, 2008 Technical information is a bit sparse but basically it looks to be the same principle as xcarlink etc. as far as I can see... and I think I've followed their instructions to the letter. Maybe another angle on what I'm doing wrong would be: what would I need to do to add a CD changer to the bog standard Chorus II? If the answer to that is anything other than just plug it in then that might be the issue I'm having ? Thanks very much for the reply, much appreciated. Link to comment Share on other sites More sharing options...
Mook Posted November 27, 2008 Report Share Posted November 27, 2008 Most of the MP3 and iPod adaptors actually replace the CD unit, so you have to disconnect it. Sorry, I can't be any more help with it. All I can suggest is that you talk to the vendor tomorrow to try and get a steer as to what you need to do to get it working. Link to comment Share on other sites More sharing options...
Froggy Posted November 28, 2008 Report Share Posted November 28, 2008 If you are adding a normal OEM changer it will/should just plug in and work. I would suggest plugging in the usb adapter, then remove all power to the Chorus for about 10 minutes then reconnect it. This should reset the Chorus unit and the USB adapter and hopefully the two will see each other. Link to comment Share on other sites More sharing options...
techieboy Posted November 29, 2008 Report Share Posted November 29, 2008 Does it possibly require VAG-COM to tell the car there is now a "CD Changer" fitted, or is that only required with the RNS-E and a changer? Link to comment Share on other sites More sharing options...
craigyb Posted November 29, 2008 Report Share Posted November 29, 2008 I've never had to code a CD changer or Adaptor to work on any system, concert/Symphony II or II+, nor on NAV+, they just work out of the box. But I always code them after fitting to remove the error messages. Link to comment Share on other sites More sharing options...
MrAvant Posted November 30, 2008 Report Share Posted November 30, 2008 I recently fittet the Xcarlink with my Symphony II. Initialy it would not work but as i recall i unplugged the unit several times and reconnected and hey presto it worked. Link to comment Share on other sites More sharing options...
