jonnyjambo Posted March 29, 2009 Report Share Posted March 29, 2009 (edited) Hi people I'm new to this site and after some help from fellow Passat owners, please. The rubber gasket around the base of my aerial is perished and requires replacing. To do this I believe I can lower the rear section of the headlining to get to the aerial. So can anyone please tell me how to lower or remove the headlining to get to the aerial? cheers Edited March 29, 2009 by jonnyjambo Link to comment Share on other sites More sharing options...
jonnyjambo Posted March 30, 2009 Author Report Share Posted March 30, 2009 I should just point out, I have an estate and so its that model I require help with. Link to comment Share on other sites More sharing options...
jonnyjambo Posted April 11, 2009 Author Report Share Posted April 11, 2009 Really, can no one help!? Link to comment Share on other sites More sharing options...
rmv Posted April 12, 2009 Report Share Posted April 12, 2009 would have thought someone or agent VW would know this to assist you? Seems reasonable question as most of the querys on this site are...good luck anyway Link to comment Share on other sites More sharing options...
Totally Loaded Posted August 15, 2009 Report Share Posted August 15, 2009 I,ve only done this on a saloon. You need to remove the top part of the B pillar trim and the C pillar trim cappings and seals around the top of the rear doors. The edge of the headliner is tucked into the top of the rear screen so i had to make up a flat curved hook to refit it. The aerial base has a flying lead with either one , two or three connections depending on whether you have a telephone, GPS or normal radio. Makes sure you have clean hands and be careful no to crease the headliner when working with it. Link to comment Share on other sites More sharing options...
