mb Posted November 9, 2009 Report Share Posted November 9, 2009 Does the RS4 Avant have a rear towing eye ? Link to comment Share on other sites More sharing options...
PetrolDave Posted November 10, 2009 Report Share Posted November 10, 2009 Does the RS4 Avant have a rear towing eye ? No, only a front one. Link to comment Share on other sites More sharing options...
mb Posted November 10, 2009 Author Report Share Posted November 10, 2009 Same for my R32 as well - does no-one break down anymore ? Link to comment Share on other sites More sharing options...
Mook Posted November 10, 2009 Report Share Posted November 10, 2009 No, it's just the designers - form over function etc. but also because maybe with AWD, VW and Audi reckon you shouldn't need to be towed backwards out of a ditch Link to comment Share on other sites More sharing options...
mb Posted November 10, 2009 Author Report Share Posted November 10, 2009 But why should I have to tow others out using reverse ? Link to comment Share on other sites More sharing options...
PetrolDave Posted November 10, 2009 Report Share Posted November 10, 2009 But why should I have to tow others out using reverse ? The towing eye is not intended for you to tow - it's only meant to be used for recovering a broken down car for a limited distance at low speeds. So it's not designed to handle the loads of towing. If you want to tow something then you MUST fit a proper towbar ... but the RS4 is NOT Type Approved to have a towbar fitted (apparently Audi think there is insufficient engine cooling for towing). Link to comment Share on other sites More sharing options...
Tipex Posted November 10, 2009 Report Share Posted November 10, 2009 No, it's just the designers - form over function etc. but also because maybe with AWD, VW and Audi reckon you shouldn't need to be towed backwards out of a ditch Which is odd really, given that all VW's and Audi's will have understeered into a ditch forwards!! Link to comment Share on other sites More sharing options...
