catfood Posted February 25, 2010 Report Share Posted February 25, 2010 I appear to have an intermittent problem with my power steering, at times it can be stiff at low speeds or when parking, other times it seems fine. I seem to remember reading somewhere that there is a sensor on the steering column to feed the steering in and out depending on how quickly you`re going, looked for a thread but to no avail. Any advice welcome. Link to comment Share on other sites More sharing options...
PsYcHe Posted February 25, 2010 Report Share Posted February 25, 2010 Depends on which year you have... If it's newer then you may have servotronic (automatically adjusts the steering response). You may have a problem with the power steering pump, or the belt that drives it, or maybe even the filter is clogged. Take the filter out of the reservoir and have a look to see how much crud is in it and give it a clean. Link to comment Share on other sites More sharing options...
catfood Posted February 26, 2010 Author Report Share Posted February 26, 2010 It`s a 99 so has the servtronic which I think is the problem, I`m wondering whether it`s an easy fix or not. Link to comment Share on other sites More sharing options...
PsYcHe Posted February 26, 2010 Report Share Posted February 26, 2010 Pull the relay from the panel below the passenger's feet and see how it behaves. This essentially turns it into a non-servotronic unit. Link to comment Share on other sites More sharing options...
r8dream Posted February 27, 2010 Report Share Posted February 27, 2010 i had same problem and its listed here, http://www.tyresmoke.net/forum/audi-a8-s8/118732-power-steering-died-there-manual-rack-fits-8-a.html Link to comment Share on other sites More sharing options...
catfood Posted February 27, 2010 Author Report Share Posted February 27, 2010 Thanks all, much appreciated. Link to comment Share on other sites More sharing options...
Goz Posted February 28, 2010 Report Share Posted February 28, 2010 Hi, my servotronic (2001) also started acting up, it would switch on and off erratically, in the end I read on Audi | A4 A6 S4 TT A5 S5 | New, Used Reviews, Test Drives - Audiworld.com that some guys over there took out the servotronic relay switch anyway because they didnt like the light steering feel. So I took mine out too (its in the passanger footwell). At first I wasnt too sure about the heavier steering at parking speeds, but you soon get used to it, frankly now I would never go back to servotronic, its too light. Link to comment Share on other sites More sharing options...
