TJ R32 MKIV Posted June 16, 2010 Report Share Posted June 16, 2010 Hello folks, New member so apoligies if im going over old ground. Recently bought my R32 car is running amazing, just a slight problem. When i start the car the engine revs to just over 1000 for about a minute before dropping to idle. i've read the threads about the smaller fan being the prolem but nothing really matches this description can any1 help, Cheers. Link to comment Share on other sites More sharing options...
Mook Posted June 16, 2010 Report Share Posted June 16, 2010 Welcome to Tyresmoke Normal behaviour on a Mk4 R32 - it's the cold-start cycle. Link to comment Share on other sites More sharing options...
TJ R32 MKIV Posted June 16, 2010 Author Report Share Posted June 16, 2010 Cheers mate, So theres nothing actually wrong then. Not had any problems with the car yet touch wood, just my mate had a problem with his mk4 and the fan system needed replacing. Link to comment Share on other sites More sharing options...
Mook Posted June 16, 2010 Report Share Posted June 16, 2010 No. Nothing wrong Link to comment Share on other sites More sharing options...
Cuprabob Posted June 16, 2010 Report Share Posted June 16, 2010 As said above normal behaviour. If you want to check the fans are working correctly, start the car, make sure the a/c is on and the small fan should be running continuously. If not then you have the very common fan problem with the low speed control circuit in the fan burning out. Link to comment Share on other sites More sharing options...
