completelylost Posted September 4, 2011 Report Share Posted September 4, 2011 I was cleaning my car out today and I had the car ticking over to check the results of the major service that was carried out last week. That all seemed good so I started to clean out the boot, and to do so I had to open it with the remote, so I removed the key from the ignition, and used the remote and then put the key back in the car and started it up. Next time I looked the car doors were locked, the engine running and the boot was still open. No problem I thought, I'll disconnect the battery and use the plastic valet key to open the drivers door (my spare isn't with me): So I did that and the engine still runs. I though that only happened with Diesel cars and not petrol! Any thoughts on how to stop the car (it's still running as I am typing)? And any thoughts on why the car locked? Link to comment Share on other sites More sharing options...
Tipex Posted September 4, 2011 Report Share Posted September 4, 2011 I'm guessing it's an auto so you can't just stall it? Otherwise, stop the air getting in the engine by blocking the air intake, it will then stall. Link to comment Share on other sites More sharing options...
completelylost Posted September 4, 2011 Author Report Share Posted September 4, 2011 I can't cut the air flow off as the bonnet is closed and the air intake is set to far behind the grill to be able to stop the air: Thanks any way Link to comment Share on other sites More sharing options...
m4ttm4son Posted September 4, 2011 Report Share Posted September 4, 2011 You haven't managed to open the driver's door with the valet key? Link to comment Share on other sites More sharing options...
completelylost Posted September 4, 2011 Author Report Share Posted September 4, 2011 No: I have tried, but I think that function is disabled with the engine running. Link to comment Share on other sites More sharing options...
Tipex Posted September 4, 2011 Report Share Posted September 4, 2011 No folding rear seats or ski hatch a small child could squeeze through? Does it have frameless windows? If so, unravel a metal coat hanger, poke it between the glass and the rubber into the car, see if you can either hit the unlock button, or turn the the key off. Actually, try connecting the battery back up, then try the valet key or the above, as it may be that not having the battery connected won't let the central locking work. Link to comment Share on other sites More sharing options...
Calm Chris Posted September 4, 2011 Report Share Posted September 4, 2011 Discon the fuel ? Mole grip and clamp pipe ? Link to comment Share on other sites More sharing options...
completelylost Posted September 4, 2011 Author Report Share Posted September 4, 2011 Ski Hatch, but alas, no small children as lost them when cleaning chimneys! I'll test the other suggestions Link to comment Share on other sites More sharing options...
cruiser647 Posted September 4, 2011 Report Share Posted September 4, 2011 AA or RAC for now. OR, get a long pole, open the boot and ski hatch, see if you can open any of the doors with the long pole? Then get onto eBay and purchase an unused key - get it cut and then programme it to unlock/lock the doors. Link to comment Share on other sites More sharing options...
Calm Chris Posted September 4, 2011 Report Share Posted September 4, 2011 If the key is on a ring, a decent bit of bamboo, aim to 'stab' the ring, if you manage that then you should be able to twist the ring around the key thus turning things off and realising the key from the mech. I', pretty sure Audi keys don't have the simple push in / out key type of BMW's- if they did then the use of a pole to push the key would be easy. If the car has a start button does pushing that stop the car ? Link to comment Share on other sites More sharing options...
completelylost Posted September 4, 2011 Author Report Share Posted September 4, 2011 Thanks everyone the AA did it using a min-air bag to make a gap between the door and frame and then a long wire to push the window button, after that it was easy.ame Before that he tried to use the Valet key, managed to break it and damage the lock: does anyone know if a lock can be rebuilt/pins changed over? Sure the auto-locking behaviour isn't normal, or is it? Link to comment Share on other sites More sharing options...
cruiser647 Posted September 4, 2011 Report Share Posted September 4, 2011 Thanks everyone the AA did it using a min-air bag to make a gap between the door and frame and then a long wire to push the window button, after that it was easy.ame Before that he tried to use the Valet key, managed to break it and damage the lock: does anyone know if a lock can be rebuilt/pins changed over? Sure the auto-locking behaviour isn't normal, or is it? He broke it! - Ooops! They are only plastic, so he should know better. Auto-locking IS normal on my many Audis and VWs. Open 1 door and then shut the door, and if nothing else is used or activated, then the doors lock after 1 minute. Happened to my Bora in the VAG indy garage - I only had 1 key, but luckily the garage had the knowledge/reprobate characters to get in......... Phew! Link to comment Share on other sites More sharing options...
Tipex Posted September 4, 2011 Report Share Posted September 4, 2011 The doors should only ever lock themselves under two circumstances- 1. If you unlock the car, but don't open any doors or boot, the car will re-lock itself. 2. If the anti hi-jack feature is enabled the doors will lock when you pull away, but shouldn't lock until you are doing 5-10mph. Link to comment Share on other sites More sharing options...
Cuprabob Posted September 4, 2011 Report Share Posted September 4, 2011 One thing that commonly happens is the door controller fails so it doesn't know the door has been opened. In this case the car will re-lock after the door has been opened and closed. Easy to diagnose, interior light doesn't come on or lights on buzzer doesn't work when door is opened Link to comment Share on other sites More sharing options...
cruiser647 Posted September 4, 2011 Report Share Posted September 4, 2011 (edited) One thing that commonly happens is the door controller fails so it doesn't know the door has been opened. In this case the car will re-lock after the door has been opened and closed. Easy to diagnose, interior light doesn't come on or lights on buzzer doesn't work when door is opened Infact, that was the case with the Bora - now I think about it. On my Audis, that is not the case and they will relock after 1 minute if only 1 door is opened and closed. I should think you can chage the settings in VAG-Com? Edited September 4, 2011 by cruiser647 Link to comment Share on other sites More sharing options...
Scotty Posted September 4, 2011 Report Share Posted September 4, 2011 Tipex describes how it's been on my three Audis. Any door gets opened and it won't lock on it's own. Link to comment Share on other sites More sharing options...
completelylost Posted September 4, 2011 Author Report Share Posted September 4, 2011 I think that this happened: key out, drivers door open, boot unlocked, car started door shut, no movement, drivers door locked. I don't know if it's a door controller as that sounds different to the situations described above. The valet key broke as the nice AA man seemed to damage the lock barrel so the key couldn't be pulled out, we tried with my flip key and that got stuck as well, but we got it out. I'm thinking of getting the lock rebuilt, if that's possible, to avoid changing all the barrrels. Link to comment Share on other sites More sharing options...
