Climate not getting cold
ascttt
Hi I have just gone through the painful problems with the blocked drains, geting the inside soaking wet. Now it seems that the air con is not cooling. I have checked the fuses and they are all OK. The controls for the air con seem to be OK if I set the temp down the fans kick in, but not with blast of cold air I think you should get, it just doesn't freeze your nuts off, if you see what I mean. Is there anything else I could check? or am I having to go back to the stealer?
