DHA Posted May 3, 2004 Report Share Posted May 3, 2004 If i was to run High Boost 9 all the time on my S3 would there be any ill effects? Link to comment Share on other sites More sharing options...
RS4_Barry Posted May 4, 2004 Report Share Posted May 4, 2004 I thought the revo system ony allowed you to make adjustments within the manufacturers tolerances so you should never exceed the maximum boost for a K04 turbo. I presume you would be using good fuel though. Link to comment Share on other sites More sharing options...
DHA Posted May 4, 2004 Author Report Share Posted May 4, 2004 Only ever drinks optimax and if i cant get hold of that then i switch it back to the stock setting. Might give it a go after the service is done in 2K miles Link to comment Share on other sites More sharing options...
Cupramax Posted May 4, 2004 Report Share Posted May 4, 2004 The boost settings on Revo have no effect on the timing and hence the fuel you use will be irrelavent. The timing setting is the one which will be effected by using optimax, 95 ron agressive setting is timing 5 and optimax agressive setting is timing 7 therefore setting to use with optimax is HighBoost 9 Timing 7. I take it you have an SPS3??? The ECU will still back off if it detects detonation regardless of settings you select. Link to comment Share on other sites More sharing options...
DHA Posted May 4, 2004 Author Report Share Posted May 4, 2004 Yeah i have SPS3, just dont want the car to go pop! Link to comment Share on other sites More sharing options...
Cupramax Posted May 4, 2004 Report Share Posted May 4, 2004 I've ragged the nuts out of mine for nearly 2 years and its not gone pop yet, most of those have been run on high boost 5 timing 7. Link to comment Share on other sites More sharing options...
DuncS3 Posted May 4, 2004 Report Share Posted May 4, 2004 I dont think you will find REVO recommending High Boost 9 all the time, in fact I think they recommend low boost 9 timing 6 as a general day to day maximum (on good fuel). Personally I normally run High Boost 6 Timing 5 One thing that confuses me is that people say only use the higher settings for trackdays etc, but thats the time when the engine is caned the most! Dunc Link to comment Share on other sites More sharing options...
M3Will Posted May 4, 2004 Report Share Posted May 4, 2004 Im using HB5,T5 and all is well (though I only changed from standard setting today ) cmon rs3...hurry up pleeeeease. Link to comment Share on other sites More sharing options...
M3Will Posted May 5, 2004 Report Share Posted May 5, 2004 update... totally shat meself today when getting onto the motorway. put my foot down in 4th to say bye-bye to an mr2 and the car just died on me... managed to limp all the way to the dealer who fitted the Revo, all the time thinking the worst like turbo fubar or whatnot. dealer checked it out and found that the induction pipe jubilee clip had come loose and when I put my foot down, must have come loose - hence not being able to drive above 60mph (not good on mway when weeing down and mad lorry drivers up me arris), and coughing and spluttering all over the place. dealer just put the clip back on, tied it up correctly (this time), and reset the error codes - job done. back to being a happy camper (thank fvck) Link to comment Share on other sites More sharing options...
Cupramax Posted May 6, 2004 Report Share Posted May 6, 2004 Lol, this happened on mine at full tilt when doing a power run on Stealths rolling road. You've never seen so many worried faces in your life Not least someone from Revo who was acting as ballast and was sat on the front wing right next to the pipe that came off. Twas somewhat of a brown trouser moment Link to comment Share on other sites More sharing options...
Paul Posted May 6, 2004 Report Share Posted May 6, 2004 had the same with mine, infact having that hose replaced as its lost its shape. i have also beefed up the jubilee's to JCS High Grip stainless steel ones. as the standard jubilee couldnt hold it on, and it kept blowing off. Link to comment Share on other sites More sharing options...
DHA Posted May 6, 2004 Author Report Share Posted May 6, 2004 any chance of a pic of that paul? Link to comment Share on other sites More sharing options...
s8n Posted May 6, 2004 Report Share Posted May 6, 2004 [ QUOTE ] any chance of a pic of that paul? [/ QUOTE ] Just put hairspray on the hose ends before you clamp em, wont come off then Link to comment Share on other sites More sharing options...
Mo-S3 Posted May 6, 2004 Report Share Posted May 6, 2004 S8n... u serious ??? Link to comment Share on other sites More sharing options...
Paul Posted May 6, 2004 Report Share Posted May 6, 2004 Its not quite complete yet... As at the moment i have a huge industrial clamp holding it on till i get the turbo hose replaced, It kept blowing off the steel pipe on LHS of engine, where it goes to first IC. Audi's temp repair lasted three miles before it blew off, so i repaired it myself. good job as i have got to wait nearly another two weeks till they have booked me in. for now I have replaced the hose clips on the hose to airbox, and second IC to mainfold. Im going to supply Audi with the clips to do the last hose. You can see the clips on Waks site. http://www.wak-tt.com/mods/hoseclips/hoseclips.htm The hose clips are great. far stronger than normal jubilee's and wider to give better foot print. You can give these some grief without fear of over tightening. Link to comment Share on other sites More sharing options...
Paul Posted May 7, 2004 Report Share Posted May 7, 2004 I have started another thread about hose clips/blown hose see here... HERE Link to comment Share on other sites More sharing options...
