Tomk Posted December 20, 2004 Report Share Posted December 20, 2004 Ok can someone help me set this up ? i can use it at home on the network , but i dont know how to use it remotley, i want to be able to controll my home pc from work , but have not got a clue how to start ! i use a router at home for my ADSL if it makes any difference , and have static ip's anyone able to help ? oh also have a pda that would be cool to set it up though too Link to comment Share on other sites More sharing options...
CarMad Posted December 20, 2004 Report Share Posted December 20, 2004 MMM Depends what you want to do to control it. Microsoft Netmeeting can be used to control a PC remotely as can some products from Norton etc. You will probably have to open some ports up on your firewall to allow it, they will most likely reject any requests before you even get started. I would try and do it between two local PCs on your network before you put the internet into place. After that it shouldn't be too hard to work out I don't think. Link to comment Share on other sites More sharing options...
drpellypo Posted December 20, 2004 Report Share Posted December 20, 2004 If you've got a fixed IP then, in theory, you should just be able to install VNC at source, and set it to accept incoming connections (password it though.. something complex), and then at work, as long as you don;t have firewall restrictions, just run the client, and ask it to connect to the IP. YOu sure you have a fixed IP though? Not a lot of ISP's offer this, as they usually use DHCP to assign addresses ad hoc. Link to comment Share on other sites More sharing options...
Tomk Posted December 20, 2004 Author Report Share Posted December 20, 2004 well my pc has a fixed ip but i presume the router will have another ip ? thats prob the one i need , then my pc name, im just not sure, cant see it anywere on the net to show me how Link to comment Share on other sites More sharing options...
JaffaCake Posted December 20, 2004 Report Share Posted December 20, 2004 Tomk, it's not that difficult to setup if you know what you're doing but, assuming your admin at work has a clue, it won't be allowed through your work systems. Also, the remote desktop feature of WinXP is far better than VNC anyway. VNC also isn't too secure. Link to comment Share on other sites More sharing options...
drpellypo Posted December 20, 2004 Report Share Posted December 20, 2004 Your PC will have a fixed IP from the DHCP on your router (probably 192.168.0.x), which is internal to your network. Your router will pick an IP up from your ISP which will unlikely be static, so will change everytime your router gets an connection from your ISP. In which case, you're better looking at an ap that runs independant of IP, and works through Messenger, or some other login based system. Link to comment Share on other sites More sharing options...
Tomk Posted December 20, 2004 Author Report Share Posted December 20, 2004 fair point yes i see that , remote desktop is usable at work (i use it here) but not sure how to connect to home pc though the router etc Link to comment Share on other sites More sharing options...
Hopsta Posted December 20, 2004 Report Share Posted December 20, 2004 You need the external (public IP adress) that your router uses on the internet. Unles its a static one you'll have a nitemare keeping track of it. You'll then need to open the relevant ports on your router at home to allow the RDP. Link to comment Share on other sites More sharing options...
Beast Posted December 21, 2004 Report Share Posted December 21, 2004 The VNC port that you need to open up or redirect is 5900 by default. Good luck! Just be prepared as this isnt a very safe method or remote computing. Link to comment Share on other sites More sharing options...
Tomk Posted December 22, 2004 Author Report Share Posted December 22, 2004 its all got to complicated for me ! Link to comment Share on other sites More sharing options...
