New VAG keys
Rachel
The photo below (thanks VW Vortex) shows the new key system in the newly released Passat. From the photo, it looks as though there is no key "blade" - just a little remote "brick". The images of the driver's side of the car seem to indicate it is "de-locked".
It's a neat idea, but I have one concern. Does it require internal power (used for lock/unlock) to also talk to the car? What happens when the power goes in the key? I'd guess you are effectively locked out of your car, something of a problem the current VAG keys do not suffer.
What do you guys think?
I would suspect its like the Saab keys. There is actually a blade key inside which you can pop out to manually open the doors.
As for the ignition, it is actually powered by the car not the key (again I'm assuming its liek the Saab system), the key is just passive. Like the immobilser chip in your current key. The ignition reads it, and then unlocks the ignition so you can start the engine.
Its the same system that you have been able to get in High end Lexus / Mercs for a while now. Oh and the Micra / Megan has also had it for quite a while now as well.
Its great to be able to walk up to the car and pull the handle without even touching the key. All you do then is twist the ignition as if the key was in or press a button depending on the system. As far as I know it alerts you as to when the battery is getting low and they also change them at each service in a Lexus at least.
A smart idea till (for example) wife needs to borrow the car. Chap drives to the station, hops out with engine running, wife hops in drivers seat and heads off. Chap 50 miles away on train when wife pulls into Tescos, switches off engine, and realises key is in hubbys pocket heading west...
There was an article in a magazine that had that very thing happpen. Driver never really touched the key so completely forgot to hand it in as he left on the train for a trip leaving the person in the office with no keys to drive the motor home.
As for the key battery. I thought Lexus and Audi key rings also charged the battery to keep it charged ? Lexus change them at every other service or something similar to ensure a memory effect doesn't happen.
Didn't BMW trial something like storing the car's electronic log on the key ? Sounded a smart move - you go into the dealer, who slots your key into a reader, and says "ah yes, you're due for X, you need a top-up of oil, and there's an early fault developing in Z". Or something like that. And of course (unlike, say, a separate credit-card sized electronic logbook), it's always updated when you stick your key into the ignition.
