Headerss Posted July 19, 2005 Report Share Posted July 19, 2005 Hey, I have a 2002 A4, 2.4 and i am facing some difficulty when i want to start the car. THe starter is hitting perfectly since i recentky changed the battery, but it seems as if no command for the fuel to help start the vehicle. I keep on trying until it finally starts, it may take around 4-5 hits. Has anyone experienced this before? Link to comment Share on other sites More sharing options...
Soapsuds Posted July 19, 2005 Report Share Posted July 19, 2005 If a car (any!) fails to start easilly, always check the simple stuff first as 99% of the time, its these bits.... Leads, plugs, coil pack etc. If its got a FSH, it shouldnt be doing this! Diagnostic test will tell you more.... Link to comment Share on other sites More sharing options...
stratty31 Posted July 19, 2005 Report Share Posted July 19, 2005 sounds like a coolant temp sensor..you'll find it on the rear of the engine against the bulk head..it's a bit tight on a 2.4..remove the main air intake pipe to improve access. *******WARNING: DON'T TRY AND DO IT WHEN THE ENGINE IS HOT...YOU WILL GET BURNED!!!!!***** Link to comment Share on other sites More sharing options...
