Denim Posted July 19, 2005 Report Share Posted July 19, 2005 Easiest place to pick up 12v ignition on power apart from radio ? 2002 A4 Link to comment Share on other sites More sharing options...
peterb Posted July 19, 2005 Report Share Posted July 19, 2005 I don't think you'll get it from the radio. All recent radios use a permanent 12V supply, with power on/off sent as commands over CAN bus. On the A6/RS6 there are a series of relays mounted above the driver's knees - one of those has an ignition-switched 12V supply, easily accesible on a screw stud terminal. I don't know whether the A4 will have a similar arrangement. Link to comment Share on other sites More sharing options...
Denim Posted July 20, 2005 Author Report Share Posted July 20, 2005 Forum = A place where the knowlegable give advice to the not so knowlegable Any advice appreciated Link to comment Share on other sites More sharing options...
a4tdi130 Posted July 20, 2005 Report Share Posted July 20, 2005 Fuse boxes are your friend!. Get a multimeter and touch the top of each fuse to see which ones are ignition switched. Then (this obviously isn't the best way to do things but it's the method I always use because you can easily remove any trace of DIY mods incase you break something) take the fuse out, wrap your connection around it, then plug the fuse back in. Link to comment Share on other sites More sharing options...
gizze Posted July 20, 2005 Report Share Posted July 20, 2005 Fuse 5 in the fuse box for 12v switched. Link to comment Share on other sites More sharing options...
mb Posted July 20, 2005 Report Share Posted July 20, 2005 Bus-bar under the drivers knee always a favourite for me ! Link to comment Share on other sites More sharing options...
Denim Posted July 20, 2005 Author Report Share Posted July 20, 2005 Thanks guys Bus bar Link to comment Share on other sites More sharing options...
TiSwAs Posted July 20, 2005 Report Share Posted July 20, 2005 Bus Bar A conducting bar that carries currents to supply several electric circuits. Link to comment Share on other sites More sharing options...
