Rusty Posted July 23, 2005 Report Share Posted July 23, 2005 Hi guys, can anyone help One of my mates owns a VW polo 1.6 16V Gti(2000) and he's been complaining about getting a nasty smell of petrol on occasions. I connected vagcom to the car and ran an Autoscan on it. Its came up with the following code. Controller: 036 906 033 A Component: 1.6l/4V SIMOS3 00HS3259 Coding: 00031 Shop #: WSC 00788 1 Fault Found: 17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low P1103 - 35-10 - - - Intermittent Readiness: 0010 1001 I cleared the code and told him to run the car for a few days and I'll re-check it again. I have told him that he may require a new Lamba sensor but I'm a bit confused on the following issues. 1) Does the car have two lambda sensors (1 before & 1 after cat), and 2) What lambda sensor does this fault code effect? Cheers Rusty Link to comment Share on other sites More sharing options...
mulkbear Posted July 23, 2005 Report Share Posted July 23, 2005 The fault code reads "17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low" B1 S1 is short for bank one sensor one. as the car is a 4 cylinder (1 exhaust manifold) there is only one bank, and sensor one refers to the first lambda (pre cat) Before you go and change the lambda probe check the connection terminal and the plug mounted under the vehical There is a running fault because the readeness codes are not set as well Link to comment Share on other sites More sharing options...
Rusty Posted July 25, 2005 Author Report Share Posted July 25, 2005 Thanks for your reply, I'll get him to check the connection of the lambda sensdor to the harness. What do you mean by the readiness code for the lambda sensor. Will a new Lambda sensor eliminate any readiness code issues or do you have to adapt some thing withing vagcom. Would any readiness code issues cause the car to be over-fuelled. Cheers Rusty Link to comment Share on other sites More sharing options...
mulkbear Posted July 25, 2005 Report Share Posted July 25, 2005 When readiness setting are not set the car is not fimilar with itself e.g the ecu does not know where the red line is or what advance the timing should be at, so the vehical runs at basic setting. It can take up to 200 miles for the car to set it self because the vehical has to been driven in all sorts of conditions to "get to know itself". Link to comment Share on other sites More sharing options...
