Waitey Posted September 13, 2005 Report Share Posted September 13, 2005 Hi there just a quick question, I am going to disconnect my battery to see if the drainage holes are blocked up,as the carpet in the passenger footwell is getting damp. Do i need to reset the radio code after reconnecting, if so do i have to get it from stealers? Is there also a specific order to disconnect the leads and will anything else need resetting? Not such a quick question really, oh well Cheers Big Al Link to comment Share on other sites More sharing options...
Mook Posted September 13, 2005 Report Share Posted September 13, 2005 The radio will normally be OK for 20 minutes or so, but you will find the code towards the back of your service book, in the Stereo section. Your dealer will not normally have this, although as far as I'm aware, they can get the code from VW after a few days as long as you have your car's V5 to show that you own the car. If all else fails, you can get it reset by various companies that advertise on Google - try something like "radio code reset" or similar. Always disconnect the negative lead (normally black) from the battery first. When you're hooking everything back up, reconnect the negative lead last. HTH Link to comment Share on other sites More sharing options...
Waitey Posted September 13, 2005 Author Report Share Posted September 13, 2005 Cheers for that will have a go, it wont be the end of the world if cant get music back our lass listens to some right Cheers Link to comment Share on other sites More sharing options...
pontyslapper Posted September 13, 2005 Report Share Posted September 13, 2005 VW stealers should do the code for free - says so in the radio manual. When my Passat was in for service, the system was down. If your Passat is quite new - it might have the stereo that is paired to the car - which means even when the battery is disconnected, the radio will stay 'alive' without the need to re-enter the code. Well, thats my understanding of the 2004-> manual and radio. Link to comment Share on other sites More sharing options...
jmc7098 Posted October 26, 2005 Report Share Posted October 26, 2005 That's correct. My 1.8Ts radio had gone a bit mental, so I took the fuse out and left it over night. When I put the fuse back in and then turned the radio on I got the message "CODE" or something like that. I then tuurned the ignition and the radio recognised the car and no code was required. (The problem I had with the radio was fixed as it had reset). Link to comment Share on other sites More sharing options...
