Anyone know of a grommet in the passenger footwell
pomme
This might help you out a little, its not easy to get to on the engine bay side of things but it is there.
Try running a smaller ferit cable through 1st then attach that to your main heavy cable and pull it back through - an extra tip as well is to give it a squirt of WD40 or something to help it slide through where you have joined the 2 cables 169144-ok.gif
http://www.jamesnortham.com/vw/ice.htm
cheers
matt
Hum, i may have a look behing the clutch, as this might save me taking out the glove box.
There is only 1 problem with that, being your cable to the battery will end up on the wrong side of the engine bay and you will have to run it across.
I managed to do mine no problems with out taking the glovebox out at all, I just stuck my head under the footwell with a torch and you should be able to see it. It is tight but you can feel it with your hand up the back.
cheers
matt
