"groaning" from the steering
Huss
Guys
My 8 has developed a loud groaning sound when I turn the steering wheel. It only happens when I turn left and appears to come from the column itself - although it could be tramsmitting from anywhere in the steering I suppose?
It was intermittent but now is there virtually 100%. It not rubbing around the cluster as I moved it up/down/in/out etc to no avail.
I've checked the fluid level and that is spot on - so no leak in the rack itself I suspect. Before carting it to the stealers, any pointers as to what it might be? At least it'll give me a fighting chance in the diagnosis discussions.
Tks,
Sorry, I was in a rush earlier.
I once had the car on axle stands and turned the s/wheel, got a simlar noise (wheels off the ground could change the noise as not got the weight on'em?) and noticed that the tops of the shocks turn in the turrets as the noise is made. If the vibration does come from there, it could be amplified through the column(?). If I am talking out of my chuff, please advise? blush.gifgrin.gif
Sorry for not responding fellas...been away for a few days.
So the consensus is to change the fluid eh?
Well it's going in for the dreaded 80,000 mile service before Christmas so I may as well yet add another bit of work to the long... list.
BTW off topic but is it true that the thermostat is behind the water pump? If so it surely makes sense to have that changed along with the pump and belts? The reason I ask is I've never heard anyone mention it.
Thanks for the steering tip fellas I'll let you know how I get on!
regards,
The stealer has said that they will change all supplemental belts (air con, pump etc at cost) as they will be taking the front off anyways.. what with the gearbox oil change and a service, plus the steering fluid change I dread to think what this one will cost??
