sat nav switch power problem
right got a problem with the sat nav+ .
Started with going out to the car to start it and battery was flat [had sat for about 8 days without being moved ] ,got audi assit out and got it started no problem and was told something was draining the battery.
Booked it into audi and the say the problem was the sat nav and were going to replace when they found out that it was a retro-fit.
Had the retrofit done by a local audio shop ive used for years and it all works fine but it wont turn of with the ignition [ its a plug and play wiring harness that i bought with the unit ]so im thinking this might be the problem that it,s not on a switched power supply.
Has anyone else had this problem and is it a easy fix i can do myself
any thoughts would be welcome
thanks paul
I naturally defer to Craig for a definitive answer but I think I used the fuse for the heated washer jets for the switched 12v on my nav. I think it might be no 5 but thats from memory.
I have had no battery draining problems with it.
Hope that helps.
Regards
C
This thread has some info
http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/482995/page/0/fpart/2/vc/1
Ah just found it gizze writes '
If the fuse box is the same as the A4 then fuse number 5 is 12v switched'
http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/1,2,12,15,22,25,26,27,3/Number/398670/page/0/fpart/2/vc/1
I had power problems (drained system twice) when I had my Dension MP3A wired into my RNS-E. It turns out that it stayed live and would often turn itself on (during the night) - it too needed a switched live, however in the end I removed it and reconnected the std CD changer.
Audi assist chap was helpful in getting the car going again. And I had it in the dealers over a weekend on a charge/drain monitor to see if anything else could be the cause. All the other kit was given the all-clear so I know it must have been the dension unit.
this is the unit
thor where in scotland are you mate a little hands on if you like jump.gif169144-ok.gif
I,m from Airdrie has your nav unit never turned off with ignition since install.To get access to wires under fusebox remove kickpanel on drivers side,will help if you want but not too eager to tamper with somebody elses baby.
John
never turned off from day one , ive had the kick plate under the steering wheel off before as im running power of the relay plate for a hdd/rear tv install. Is it in there somewhere ,what i can do is have the plate off run threw at ure convenience show me what wire and what to do and ill do the rest .Find it easier to do a job when shown practical rather than theory [ just my why of learning ]
