DanG Posted January 22, 2006 Report Share Posted January 22, 2006 Anyone else had this come on? Red AIRBAG light in the cluster... This is the third time its come on now, usually the dealer has just reset it using a VAGCOM terminal, but it will be getting the full treatment this week at some point as there is obviously something wrong with the passenger seat harness I think. Is it a common fault?? Link to comment Share on other sites More sharing options...
Tizzy Posted January 23, 2006 Report Share Posted January 23, 2006 Had this just before Christmas in the S4. It ended up on all the time. Dealer said it was a fault with the seat pressure sensor & sorted it quickly under warranty. Link to comment Share on other sites More sharing options...
whimsical_chris Posted January 23, 2006 Report Share Posted January 23, 2006 Wiring under the seats is an issue, had it with mine. Once they found the problem it has been good since, but they did replace the airbags / steering wheel / control unit before they listened and checked the wires Just resetting the system will make the light go out, but wont sort the problem !!! c Link to comment Share on other sites More sharing options...
