olivia Posted January 31, 2006 Report Share Posted January 31, 2006 TURN THE CAR ON TURN IT OFF EITHER RIGHT AWAY OR AFTER BE DRIVEN FOR ANY AMOUNT OF TIME THERE IS A TICKING NOISE IN THE ENGINE NEAR THE BOTTOM VW SAYS ITS NORMAL IE BURNING OF FUEL BUT THIS IS LAST FOR BETWWEN 15_TO30 MINS TILL IT STOPS ITS LOUD ENOUGH TO HESR IT STOOD A COUPLE OF FEET AWAY ANYONE HAVE ANY IDEAS THANK YOU NEWBIE Link to comment Share on other sites More sharing options...
RossG Posted January 31, 2006 Report Share Posted January 31, 2006 Is it not just the exhaust system, and hot bits of the engine cooling down. The ticking is the sound of the metal contracting back to its normal state. My exhaust pipes grow in lenght noticably ) when they are hot, so they have to retract as they cool Link to comment Share on other sites More sharing options...
Mook Posted January 31, 2006 Report Share Posted January 31, 2006 Welcome to Tyresmoke Boris The ticking noise if normal - there is a a carbon filter just behind the front offside headlight which ticks away like crazy. This is completely normal. It could also be your exhaust contracting if the car has been driven very hard, but from what you say, I don't think this is the case? BTW, turn off your CAPS LOCK - otherwise it looks like your shouting... Link to comment Share on other sites More sharing options...
olivia Posted January 31, 2006 Author Report Share Posted January 31, 2006 HI THANKS BUT THE NOSE IS COMING FROM BEHIND THE BOTTOM GRILL BELOW THE NUMBER PLATE BUT NOT FROM THE RADIATOR IT IS COMING FROM THE THE PARTS AT THE BOTTOM FRONT OF THE ENGINE ???? Link to comment Share on other sites More sharing options...
olivia Posted January 31, 2006 Author Report Share Posted January 31, 2006 caps lock off sorry its in vw as we speak for the faulty fans which cool the engine but i just know they havent got a clue they said it was the charcol filter a few week ago which is at the top left in the engine Link to comment Share on other sites More sharing options...
Roy32 Posted January 31, 2006 Report Share Posted January 31, 2006 Hi boris and welcome, I had this exact same problem with mine and VW told me it was normal, its the recirculation pump for the coolant which runs for a while when you switch your engine off. I left it for a while then took it back and told them the ticking had got worse and they then aggreed to change it and hey presto no ticking. Get in touch with your VW dealer and ask them to change it, should be done under warrent as it is not supposed to tick. Good luck Link to comment Share on other sites More sharing options...
Mook Posted January 31, 2006 Report Share Posted January 31, 2006 Good call Roy Said it before, but I'll say it again - this place rocks Link to comment Share on other sites More sharing options...
