R32TIM Posted February 23, 2006 Report Share Posted February 23, 2006 i get a clunking/knoking noise when going over bumps/or turning the wheel which is particularly noticeable at slow speeds. ...arb...or CV joint...(i'm no mechanic) also, Mook gave me details of his VW specialist, but he's a little too far, especially if I have to leave the car with him...does anybody have any garages they use around the Swindon Area... ..but I pass AMD at least once a week, would they carry out the above....me thinks they could upgrade the arb's at the same time.... ..and maybe the haldex controller... Tim Link to comment Share on other sites More sharing options...
Mook Posted February 23, 2006 Report Share Posted February 23, 2006 AmD would do the work for you, but you'd have to be prepared to leave the car with them for the day. I have never known them complete a job while you wait, unless you're happy to wait at least half a day... I would doubt it's a CV joint - it sounds like it could be one of the bushes that's worn - could be one of many - ARBs or subframe, or possibly a ball joint. I think you already know, but you won't regret getting the Haldex unit fitted. Don't think AmD carry the ARBs in stock, so call ahead. Link to comment Share on other sites More sharing options...
Skidmark Posted February 23, 2006 Report Share Posted February 23, 2006 My son has just had a service, remap & miltek at AMD [Anni TDI]. He lives in Swindon... so we met up and made a day of it.. drop the car off & meet mid morning... into Oxford for look round and/or long lunch.... back to AMD for rolling road & chat/coffee... good day Link to comment Share on other sites More sharing options...
Dan32 Posted February 23, 2006 Report Share Posted February 23, 2006 Could it be the dreaded strut top mounts going? Understand those noises to be a symptom of that fault and if the car is in warranty it would be better for your local dealer to do the work as AMD wouldn't do it gratis. Link to comment Share on other sites More sharing options...
SJB Posted February 23, 2006 Report Share Posted February 23, 2006 [ QUOTE ] Could it be the dreaded strut top mounts going? Understand those noises to be a symptom of that fault and if the car is in warranty it would be better for your local dealer to do the work as AMD wouldn't do it gratis. [/ QUOTE ] Had mine done last week at the dealers, also changed the front springs under warranty as well. Symptoms were very similar with a grating sound when manouvering and a slight knocking through a long corner with high loads. Wanted to get the dealer onto the problem b4 having a strut brace fitted just so they couldn't wriggle out of it. Cheers, Simon. Link to comment Share on other sites More sharing options...
dubzter Posted February 24, 2006 Report Share Posted February 24, 2006 defo sounds like the strut top bearings, I've had mine replaced twice Link to comment Share on other sites More sharing options...
1monty Posted February 27, 2006 Report Share Posted February 27, 2006 Be wary of dealerships in Swindon. Had terrible customer service from them a year ago! Link to comment Share on other sites More sharing options...
deathchurch Posted February 28, 2006 Report Share Posted February 28, 2006 I have the same problem when going through long lefthand corners at some speed, can feel a knocking through the steering wheel, doesn't happen through right handers though. Took it into the dealers and they suggested swapping the front and back tyres, but that made no difference at all. Should I get them to look at the strut top mounts? Link to comment Share on other sites More sharing options...
Skidmark Posted February 28, 2006 Report Share Posted February 28, 2006 [ QUOTE ] Should I get them to look at the strut top mounts? [/ QUOTE ] arb bushes & drop-links...as well cheers Link to comment Share on other sites More sharing options...
Rachel Posted March 1, 2006 Report Share Posted March 1, 2006 [ QUOTE ] I have the same problem when going through long lefthand corners at some speed, can feel a knocking through the steering wheel, doesn't happen through right handers though. Took it into the dealers and they suggested swapping the front and back tyres, but that made no difference at all. Should I get them to look at the strut top mounts? [/ QUOTE ] Also get them to look at the engine mounts - you might have a collapsed RH one, or the engine may have been mounted to the extreme right when assembled. Does the dogbone mount (bottom one) look torqued or sitting way to close to the bottom of the engine (like only 1-2mm clearance)? If so - definitely get the mounts checked. Link to comment Share on other sites More sharing options...
deathchurch Posted March 2, 2006 Report Share Posted March 2, 2006 Thanks Rachel_H and skidmark, have just rung up the dealer and booked it in for next Wednesday and getting them to check all the things you have mentioned, will see how they get on next week, cheers. Link to comment Share on other sites More sharing options...
dazmondo Posted March 2, 2006 Report Share Posted March 2, 2006 Welcome to the real world of owning an R, ive had my beast since new and had so many knocks clunks and clatters, followed by trips to the stealers its embarasing but hey the fecker still puts a smile on my face everytime the right foot is planted to the floor, which just lately is permanant Link to comment Share on other sites More sharing options...
deathchurch Posted March 8, 2006 Report Share Posted March 8, 2006 The dealer just rang up and said they only thing they could find were worn driver side door hinges and they will replace them under the warranty. Have checked the bushes, mounts and struts all ok, and they only found a tiny bit of play in the gas shock. Anyhow, they are replacing the door hinges and then taking it back out tomorrow to see if that has cured the knocking noise. Link to comment Share on other sites More sharing options...
