Pincher Posted February 25, 2006 Report Share Posted February 25, 2006 Was having a bit of a cleanup under the bonnet today and I noticed that when I put it down again, one side doesn't sit flush with the wing. Its a few mm higher all the way along and quite noticeable. The other side is fine but it looks as though it may have twisted a bit. Anyone else seen this?? Anyo Link to comment Share on other sites More sharing options...
R32TIM Posted February 28, 2006 Report Share Posted February 28, 2006 I thought i'd reply pincher as your out here on your own... ...mines a few mm higher on the off side... Link to comment Share on other sites More sharing options...
Pincher Posted February 28, 2006 Author Report Share Posted February 28, 2006 Thanks Tim - was begining to think no-one loved me Had nother look last night and I was wrong, it only sits higher the further forward you get. It's flush going back towards the windscreen. Wonder if it may be a loose rubber bung somewhere - will have a check tonight. Link to comment Share on other sites More sharing options...
pingpongpo Posted February 28, 2006 Report Share Posted February 28, 2006 As you say don't they have adjustable rubber pads on the bonnets to set the height? Link to comment Share on other sites More sharing options...
Mook Posted February 28, 2006 Report Share Posted February 28, 2006 They do, but it's a bit weird that the bonnet has just recently gained these characteristics Or have you only just noticed it Chris and it's probably been like that since you got the car...? Link to comment Share on other sites More sharing options...
Pincher Posted February 28, 2006 Author Report Share Posted February 28, 2006 Only just noticed it TBH - I thought it might be where I had mis-fited a neadlamp protector, but when I took it off (and it broke ) it was still the same. Going to check the bung tonight. I know it's not down to crash damage causing the problem. Link to comment Share on other sites More sharing options...
Pincher Posted February 28, 2006 Author Report Share Posted February 28, 2006 Pants - wound the bung right in but made no difference. Will get the stealer to check it out on Friday - has anyone ever had a new bonnet under warranty? Link to comment Share on other sites More sharing options...
