chrisfrances Posted April 7, 2006 Report Share Posted April 7, 2006 Hi, the courtesy 5 second wash wipe is not operating, and also the beep an alarm is not working. Can these be activated via vag com, and will my audi dealer do it free, cheers. Link to comment Share on other sites More sharing options...
chrisfrances Posted April 7, 2006 Author Report Share Posted April 7, 2006 also, sorry, if so to the above does anyone know the codes, cheers. Link to comment Share on other sites More sharing options...
Paul Posted April 7, 2006 Report Share Posted April 7, 2006 beep on alarm is easily coded with vagcom, its described below on Waks site a friend of mine. No point me reinventing the wheel, when its so well documented. (These are Vagcom instuctions , not dealer! ) www.wak-tt.com/vagcom/vagcomclcoding.htm as for your washer trick, no idea. Maybe search www.ross-tech.com/index.html as for wether your dealer will do it free, thats really is a lottery question, and down to your relationship with them. Vag-com lead for your B7 A4 will have to be a newer Canbus one , if your going to buy one at any time. They changed the communication method on the later cars. Link to comment Share on other sites More sharing options...
mb Posted April 7, 2006 Report Share Posted April 7, 2006 I believe the aero wipers have removed the courtesy wipe Link to comment Share on other sites More sharing options...
DanG Posted April 24, 2006 Report Share Posted April 24, 2006 I actually had a dealer tell me that if they changed any settings using VAGCOM it would invalidate the warranty on the vehicle. I actually laughed at him to his face. So good luck and try a few different dealers..... Link to comment Share on other sites More sharing options...
crasher Posted May 3, 2006 Report Share Posted May 3, 2006 [ QUOTE ] beep on alarm is easily coded with vagcom, its described below on Waks site a friend of mine. No point me reinventing the wheel, when its so well documented. (These are Vagcom instuctions , not dealer! ) www.wak-tt.com/vagcom/vagcomclcoding.htm as for your washer trick, no idea. Maybe search www.ross-tech.com/index.html as for wether your dealer will do it free, thats really is a lottery question, and down to your relationship with them. Vag-com lead for your B7 A4 will have to be a newer Canbus one , if your going to buy one at any time. They changed the communication method on the later cars. [/ QUOTE ] Are these suitable for all vag models? Craigyb did my S8 a while back, but now i have VAG-COM i want to do the same to my wifes A6 Avant. Link to comment Share on other sites More sharing options...
craigyb Posted May 3, 2006 Report Share Posted May 3, 2006 The A6 All Road is identical to your car. I have a little utility you can use to work out what options are currently enabled/disabled and generate a new number to reprogramme the options. Link to comment Share on other sites More sharing options...
Paul Posted May 3, 2006 Report Share Posted May 3, 2006 That will probably be Basecode? Shown and linked to in this link... http://www.wak-tt.com/vagcom/vagcomclcoding.htm Link to comment Share on other sites More sharing options...
crasher Posted May 4, 2006 Report Share Posted May 4, 2006 Cheers guys. I'll plug her in at the weekend and see what havok I can reek on the avant Link to comment Share on other sites More sharing options...
crasher Posted May 6, 2006 Report Share Posted May 6, 2006 Just done it. Works a treat. Cheers for the links and info guys. Link to comment Share on other sites More sharing options...
