Chav Posted April 25, 2006 Report Share Posted April 25, 2006 Hi chaps! Not been around for a while as busy with work and life etc...! Hope you're all ok! I've noticed a few times recently when in a hurry in my cab, that the revs seems to drop then pick up again. Only happens under max. acceleration for a few seconds after starting up. Then seems to be fine. e.g. Full throttle from 5mph, and around 50-60mph revs drops a couple of K for a couple of seconds then seems to pick up again. Happens in D and S mode, but not as much in tip mode. Is this the CVT chain slipping or something? Done about 50K and not due for next service for 6K miles or so yet I think. Link to comment Share on other sites More sharing options...
Phantom Posted April 25, 2006 Report Share Posted April 25, 2006 I have had this a couple of times recently, despite having a new CVT at 14k. I think it is a quirk of the gear box, ie it can get confused if you do something unexpected. For example , releasing the brake pedal too early after engaging drive or reverse mode etc. I guess you need a certain amount of time for the CVT chain to re-position itself. I don't think it is a major problem, and I won't have to worry about it for much longer anyway. It will be interesting going back to a tiptronic after having the CVT for three years. Link to comment Share on other sites More sharing options...
lmmlmmam Posted April 26, 2006 Report Share Posted April 26, 2006 Been wondering where you'd got to! I'd guess it's maybe a control issue rather than anything manual, primarily because it doesn't happen when in tip mode. Worth getting it checked out non the less. R U seeing much of that tasty B7 S4 Cab? Link to comment Share on other sites More sharing options...
Chav Posted April 27, 2006 Author Report Share Posted April 27, 2006 Thanks for the thoughts chaps. Hi Alex! We'll have to arrange another Buxton meet etc at some point! Yep, done quite a lot of miles in the G/F's S4, but use the 3.0 as the mile muncher! Link to comment Share on other sites More sharing options...
lmmlmmam Posted April 27, 2006 Report Share Posted April 27, 2006 Good choice of G/F Chav Another Buxton meet would be good. Not sure when would be best. Are you dragging your lazy bones down souf for the summer meet? Link to comment Share on other sites More sharing options...
