audisport Posted May 22, 2006 Report Share Posted May 22, 2006 My dad's 2003 Golf Mk4 seems to be having a problem with the clutch. Every now and again when the car is started up, the clutch is already down against the floor. He got the system bled incase there were any airlocks etc and for a while it was fine. However, after a couple of weeks it did it again to me. The only way to bring the clutch back up is to put your foot under it and prize it. Has anyone had this problem? Any help would be much appreciated. Thanks Link to comment Share on other sites More sharing options...
DanG Posted May 22, 2006 Report Share Posted May 22, 2006 So the Mk4 has a hydralic clutch then? not a cable? Link to comment Share on other sites More sharing options...
audisport Posted May 22, 2006 Author Report Share Posted May 22, 2006 Yeah the Mk4 has a hydraulic clutch. Any ideas? Link to comment Share on other sites More sharing options...
mulkbear Posted May 22, 2006 Report Share Posted May 22, 2006 It is very common for the clutch master cylindrs to fail, Is it a Diesel or a Petrol ? Link to comment Share on other sites More sharing options...
audisport Posted May 22, 2006 Author Report Share Posted May 22, 2006 It is a 1.4 petrol. It shouldn't matter if its petrol or diesel for the cylinders to fail should it? Link to comment Share on other sites More sharing options...
mulkbear Posted May 22, 2006 Report Share Posted May 22, 2006 It is a cheap and easy to repair if it is a petrol but the Diesels are a bit harder. I would put my money on the Clutch Master cylinder being faulty. Link to comment Share on other sites More sharing options...
audisport Posted May 22, 2006 Author Report Share Posted May 22, 2006 Cheers for that. I'll try get it sorted. If that doesn't sort the problem do you have any other ideas? Thanks Link to comment Share on other sites More sharing options...
