WHIZZER Posted May 23, 2006 Report Share Posted May 23, 2006 My car warrenty is nearly up what should i look to be getting checked. Strut mounts Maf Link to comment Share on other sites More sharing options...
Mook Posted May 23, 2006 Report Share Posted May 23, 2006 You could get the strut top mounts and bearings checked, but if the dealer doesn't think they need replacing, they won't. Also, unless the ECU has an error logged with the MAF sensor, they won't replace it either. The majority of other stuff that goes wrong is generally not covered by warranty due to wear and tear (e.g. arti-roll bar bushes etc). Check the thread titled "Calling all Mk4 owners" for info about the cam chain tensioner. HTH Link to comment Share on other sites More sharing options...
Skidmark Posted May 23, 2006 Report Share Posted May 23, 2006 [ QUOTE ] My car warrenty is nearly up what should i look to be getting checked. Strut mounts Maf [/ QUOTE ] cooling fans....[not pulsing] ? Link to comment Share on other sites More sharing options...
robin09 Posted May 23, 2006 Report Share Posted May 23, 2006 [ QUOTE ] You could get the strut top mounts and bearings checked, but if the dealer doesn't think they need replacing, they won't. Also, unless the ECU has an error logged with the MAF sensor, they won't replace it either. The majority of other stuff that goes wrong is generally not covered by warranty due to wear and tear (e.g. arti-roll bar bushes etc). Check the thread titled "Calling all Mk4 owners" for info about the cam chain tensioner. HTH [/ QUOTE ] As i mentioned in another post, they are replacing my MAF today, even though there was no error logged. The tech said they changed it for somebody else and it seemed to solve the hesitancy, so they are trying it on mine. Guess it depends how helpful your local dealer is. Link to comment Share on other sites More sharing options...
