chasdrury Posted May 28, 2006 Report Share Posted May 28, 2006 Hi guys Back in February a blokey from the Audi dealers drove my car and suggested that my clutch was on its way out... Booked it in Audi said the clutch was on its last legs... 10k miles later, not slipped once, and then today I am driving park and an hour later come back to my car and when I start to drive the car judders as I lift the cluctch up, and its nearly impossible to get it into second.... and the clutch biting point is higher than usual and the clutch pedal feels really 'loose'..... Now, do we reckon this is the clutch thats going or another problem? Audi quoted me £850 for a new one, and the local VW/Audi specialists (Swifts in Sheffield) quoted £500.... The car is under warranty, will it be ok going to the non Audi franchise? Cheers Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 Not sure if taking it to Swifts would invalidate the warranty or not, but if you do decide to stick with Audi for the work, try Huddersfield mate, they're 100 times better. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 Not sure if the car will make it to Huddersfield It does sound like the clutch has packed in doesn't it??! Link to comment Share on other sites More sharing options...
Ian_C Posted May 28, 2006 Report Share Posted May 28, 2006 Never quite understood how using a specialist to change a part that is specifically excluded in the warranty [being a wear-and-tear item] would invalidate the 'factory warranty.' As long as you use an OE - or manufacturers suppliers sourced part direct - you should be fine. Ian Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 Yeah, it will be OE parts they use, just half price labour!! Chaz Link to comment Share on other sites More sharing options...
shark_90 Posted May 28, 2006 Report Share Posted May 28, 2006 Why don't you go for an aftermarket clutch? Might cost a little more (or with some parts less!) and get "more" for your money. I can't imagine there's a lot a dealer could invalidate a warranty on over a clutch. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 Aftermarket clutch!! hmmm.... like the sound of that? You got any links in your vast list of A4 related favourites Shark??!! Chaz Link to comment Share on other sites More sharing options...
shark_90 Posted May 28, 2006 Report Share Posted May 28, 2006 It's something I've never looked into mate, so unfortunately not. Maybe I should though, as one of the techs at APS suggested mine might be on its way out Link to comment Share on other sites More sharing options...
AZURES3 Posted May 28, 2006 Report Share Posted May 28, 2006 How many miles has the orginial clutch covered. AZ Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 40,000 nearly exactly..... Chaz Link to comment Share on other sites More sharing options...
SPLiiX Posted May 28, 2006 Report Share Posted May 28, 2006 If the clutch "feels loose" would it not just be clutch fluid??? Seems very low mileage for the clutch to go!!! I,ve done 33k Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 Well, not sure really. How can I check that? would the fluid cause the car not to engage in second properly? Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 [ QUOTE ] Never quite understood how using a specialist to change a part that is specifically excluded in the warranty [/ QUOTE ] Agreed, but you might want to tell Peter Guilder Audi that, as it was specifically pointed out to me on hand-over that such work must be done by Audi while still under the 3 year warranty, in order to maintain it. Link to comment Share on other sites More sharing options...
SPLiiX Posted May 28, 2006 Report Share Posted May 28, 2006 Chasdrury, I must admit, I aint got a clue where the Clutch fluid is. I check all my levels about once a month but you got me there. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 [ QUOTE ] [ QUOTE ] Never quite understood how using a specialist to change a part that is specifically excluded in the warranty [/ QUOTE ] Agreed, but you might want to tell Peter Guilder Audi that, as it was specifically pointed out to me on hand-over that such work must be done by Audi while still under the 3 year warranty, in order to maintain it. [/ QUOTE ] Whenever I ask Swifts about something they go on about block exemption in Europe or something which means that Audi by law cannot void a warranty if OEM patrs have been used? Not sure if they are talking though! Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 No you're right, Block Exemption is supposed to allow you to take your car anywhere. Swifts are very good. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 [ QUOTE ] No you're right, Block Exemption is supposed to allow you to take your car anywhere. Swifts are very good. [/ QUOTE ] I like the 'supposed' bit!! haha... will see what happens then... I look at Swifts and think that they cannot ever be as bad as Gilders for service so its all Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 Well it is Gilders we're talking about! Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 [ QUOTE ] Well it is Gilders we're talking about! [/ QUOTE ] Sometimes they are really helpful (on occassion, hard to beleive but true) and at other times its appauling (most of the time!!) They are always willing to sell cars though!! (wonder why!!) Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 Is Rob Searson still there? Always found him helpful. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 Isn't he the parts manager guy? Or is that another Rob/Bob... If its not him then no, he isn't there any more Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 He was in Sales. Was the guy who arranged me to test your car, and then sold me the one I ended up with. Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 [ QUOTE ] He was in Sales. Was the guy who arranged me to test your car, and then sold me the one I ended up with. [/ QUOTE ] As far I know he is no longer there, I disposed of him for letting you drive my car !!!!! [for the legal matters that was a joke, I have never kidnapped anyone!!!] Chaz Link to comment Share on other sites More sharing options...
Sparky Posted May 28, 2006 Report Share Posted May 28, 2006 Last time I drove your car, the clutch was fine, too Link to comment Share on other sites More sharing options...
chasdrury Posted May 28, 2006 Author Report Share Posted May 28, 2006 [ QUOTE ] Last time I drove your car, the clutch was fine, too [/ QUOTE ] Thanks for that input!!!! Chaz Link to comment Share on other sites More sharing options...
