khutula Posted May 28, 2006 Report Share Posted May 28, 2006 I've recently purchased a MKIV R32 - How can I tell if I already have a Milltek exhaust or not? Link to comment Share on other sites More sharing options...
jimmyp Posted May 28, 2006 Report Share Posted May 28, 2006 Check the tail pipes and see if it has the Milltek sport stamp, plus they are alot bigger than standard and the noise is awesome... Link to comment Share on other sites More sharing options...
R32North Posted May 28, 2006 Report Share Posted May 28, 2006 [ QUOTE ] Check the tail pipes and see if it has the Milltek sport stamp, plus they are alot bigger than standard and the noise is awesome... [/ QUOTE ] Aye, pretty easy to tell if they're Miltek or not!!! Link to comment Share on other sites More sharing options...
Woppum Posted May 28, 2006 Report Share Posted May 28, 2006 If it was driven hard that Miltek sign gets burnt off Best way to check is measure it. They are near enough 4" compared to the 3" as stock. Link to comment Share on other sites More sharing options...
khutula Posted May 28, 2006 Author Report Share Posted May 28, 2006 Thanks I'll measure the tailpipes. Link to comment Share on other sites More sharing options...
Dan32 Posted May 29, 2006 Report Share Posted May 29, 2006 Also, the Milltek system is polished stainless steel whereas the standard VW stuff is flat grey and rusty. If yours sounds a bit noisier than you expected, perhaps the previous owner did the flapper mod where they took off and bunged up the air tube to the solenoid flapper valve (which kept the exhaust quiet enough to pass noise tests but opened up at higher rpms) Link to comment Share on other sites More sharing options...
khutula Posted May 29, 2006 Author Report Share Posted May 29, 2006 The only rust is on the brackets that hold the exhaust up. The pipes are 4 inches across from the outer edges. If you wipe off the dirt from the back box - its shiny steel!! Would the standard back box be liek this? Link to comment Share on other sites More sharing options...
Dan32 Posted May 29, 2006 Report Share Posted May 29, 2006 The original one in my loft definitely isn't shiny. I'd say thats aftermarket. Look for a tube thats been blanked off somewhere. The Milltek system doesn't use the solenoid flapper so if its not connected it could be aftermarket. Link to comment Share on other sites More sharing options...
khutula Posted May 29, 2006 Author Report Share Posted May 29, 2006 Just got a cloth out and wiped some of the soot off to reveal on the top of both tailpipes Milltek Sport and a nice chequered flag!!!! Thanks for your help. Link to comment Share on other sites More sharing options...
R32North Posted May 29, 2006 Report Share Posted May 29, 2006 [ QUOTE ] Just got a cloth out and wiped some of the soot off to reveal on the top of both tailpipes Milltek Sport and a nice chequered flag!!!! Thanks for your help. [/ QUOTE ] Lucky old you !!! Link to comment Share on other sites More sharing options...
khutula Posted May 29, 2006 Author Report Share Posted May 29, 2006 Well chuffed... Link to comment Share on other sites More sharing options...
khutula Posted May 29, 2006 Author Report Share Posted May 29, 2006 Well chuffed - has made my day... Link to comment Share on other sites More sharing options...
