rich1068 Posted June 9, 2006 Report Share Posted June 9, 2006 Would anyone like to post up what they consider to be common faults on current Audi models? A problem they find they share with others. For example my past three cars have all been based on the Golf MKIV chassis (2x Golf MKIVS, 1x Octavia RS) and there were always the same problems cropping up for owners and drivers regardless of 'brand' eg coil packs, flasher relays, clogged throttle bodies, windows dropping, MAF etc etc. Personally I'm interested in the A3 and the 2.0T FSI engine but I imagine it would be helpful for owners of A2, A4 etc Apart from being helpful for forum members it also is a great aid to non members when they're Googling for a solution to a problem that a dealer can only solve by throwing expensive parts at a car. Include good keywords such as Audi, 2.0T, hesitation or whatever. If this has been covered before then please disregard. Link to comment Share on other sites More sharing options...
peterb Posted June 9, 2006 Report Share Posted June 9, 2006 RS6 (and, presumably, the new RS4) - expensive problems with the suspension (DRC). Link to comment Share on other sites More sharing options...
blacktemplar Posted December 14, 2006 Report Share Posted December 14, 2006 Good idea Rich - I know I've spent a lot of time on the forums looking for various problems - would be good to set up a centralised 'register' I have a bog-standard 2005 A6 2.0 TDI SE (34,000mi) and have experienced the following; - vibration at idle (injector seals) - intermittent stalling (dual mass flywheel/software) - occasional cold-start problems (as above) - intermittent parking brake release problem (software) - loud clicking from behind dash (aircon control motors) - airbag software reprogrammed under recall - drivers window auto-down failed (still to be fixed) Whew! Luckily all fixed under warranty, shudder to think how much it would have cost if I'd had to pay the stealers. Good luck with the fault register. Link to comment Share on other sites More sharing options...
Waylander Posted December 14, 2006 Report Share Posted December 14, 2006 I had the driver window auto-down failure on my A4 - fixed under warranty and now it has failed again.... Link to comment Share on other sites More sharing options...
Tunbridge Posted December 14, 2006 Report Share Posted December 14, 2006 I have a 2002 S3. Bought it with 39k on the clock 5 months ago. I've now done 43k and in that time I've had the following replaced: - 2nd Gear Synchromesh - 10 Disc Changer (kept coming up 'CDC Error' on HU) - Glove Box Lid (Annoying Rattle) - Headlight Switch (Intermittent problem with night time Illumination) Again all covered under extended warranty, other wise it could have been expensive (especially the gear box). From what I've read on here I'm not the only person to have the synchromesh fail on the 6 speed gear box. Link to comment Share on other sites More sharing options...
Waylander Posted December 14, 2006 Report Share Posted December 14, 2006 aah correction - I also have an annoying rattle from the glovebox lid Will ask for both to be rectified at 2nd AVS Link to comment Share on other sites More sharing options...
AvantSE Posted December 14, 2006 Report Share Posted December 14, 2006 Worn gearbox mounting, apparently these can go. Manifests itself as a thump when not changing gear smoothly or if the engine is stalled. Link to comment Share on other sites More sharing options...
ELSA_MAN Posted December 14, 2006 Report Share Posted December 14, 2006 Fault Guide all models. Fault - Car never leaves workshop Problem - Four rings on grille. Link to comment Share on other sites More sharing options...
chiller Posted December 16, 2006 Report Share Posted December 16, 2006 A3. 03 onwards.... Front centre armrest,not very robust and easily broken. Link to comment Share on other sites More sharing options...
Vic Posted December 21, 2006 Report Share Posted December 21, 2006 A3 (05 on) Glovebox door damper failing. I know of at least three people including myself who have had it. Link to comment Share on other sites More sharing options...
allroadman Posted December 21, 2006 Report Share Posted December 21, 2006 Current common workshop/recall bulletins 8P 13C7 Twin-mass flywheel (Recall) 02/06 4F 13C8 Belt tensioner (Workshop campaign) 07/06 4F 13D3 Vibration damper Workshop campaign) 07/06 4F 8E 15D3 Sealing plugs for cylinder head (Workshop campaign) 09/05 8P 19D8 Cooling fan motor (Workshop campaign) 07/03 4E 19E4 Scaling of the cooling system (workshop campaign) 02/06 4B 8E 20J8 Fuel pump replacement (workshop campaign 04/06 4B-8E- 8P-8Z 20L1 Checking tandem fuel pump (Recall) 12/04 8E 20L6 Accelerator-pedal module (workshop campaign) 01/06 4E 21B2 Turbo charger linkage (workshop campaign) 02/05 4F 23A1 Software update of engine ECU (workshop campaign) 12/05 4E, 8E 34D1 Cover plate for gearbox housing (workshop campaign) 05/05 96 kW TDI, 5-speed 8L-8N 42C9 Rear axle ball joints (quattro®) LL (Recall) 11/01 4E 40G1 Ft suspension mounting (Workshop campaign) 07/06 8E-8H 44F9 Michelin tyres (Workshop campaign) 03/05 4D, 4E 44G1 Michelin tyres (Recall) 01/06 8L 45B3 ABS (without ASR) control unit (Recall imports only) 03/02 4E 46E6 Software update for EPB control unit (Workshop campaign) 04/06 8L 47J4 Brake vacuum pipe (Recall) 08/03 8P 47J6 Rear left brake pipe (Recall) 03/04 4B-4D -8D 48E4 Replacing track rod ends KW (Recall) 11/99 8E 57C3 Replacement of remote control keys (Workshop campaign) 11/05 8Z 69E1 Drivers airbag (Recall) 09/02 4E 69F4 Driver’s airbag (Recall) 10/03 4F 69F7 Software update for airbag control unit (Recall) 09/05 *8P 69G3 Curtain airbag (Recall) 08/06 8N 72A1 RECARO Bucket seat (Workshop campaign) 12/05 8E 72B5 Edge guard on seat mounting rail (Workshop campaign) 01/02 8P 72B6 Anchor pins on seat frame (Workshop campaign) 03/05 8H 94C3 Xenon headlights (Recall) 04/05 8Z 97H2 Cover for starter wiring (Recall) 02/01 8L 97H6 Electrical wiring on front seats (Workshop campaign) 03/02 Link to comment Share on other sites More sharing options...
Soundwave Posted December 29, 2006 Report Share Posted December 29, 2006 Makes you wonder why anyone would want to buy an Audi after reading this thread, holy mackerel. I have had the following go wrong on my 2001 A6 4.2Q: Blocked drain hole under battery causing passenger footwell to flood. Gearbox oil leak (more severe than the usual weep most owners complain about) Sticking fuel filler cover opener thingy(?) Snapped xenon headlight auto-levelling link-bar causing warning symbol on dash - had to send off to Germany for it and was apparently rare as hens teeth. Constant goading of the driver to go faster, sut sure how to fix that one.. Link to comment Share on other sites More sharing options...
Guest crackdown Posted December 30, 2006 Report Share Posted December 30, 2006 Windows refusing to wind up- had this on A6 2.8 Quattro Sport, S6 and RS6. Happened to all four windows, usually when raining and on the motorway and each was 'fixed' three to four times! Link to comment Share on other sites More sharing options...
Tunbridge Posted January 2, 2007 Report Share Posted January 2, 2007 [ QUOTE ] Makes you wonder why anyone would want to buy an Audi after reading this thread, holy mackerel. [/ QUOTE ] The daft thing is I'd have no problems buying another Audi, I think I need my head looking at! Link to comment Share on other sites More sharing options...
Atomic Posted January 2, 2007 Report Share Posted January 2, 2007 Better the devil you know... Link to comment Share on other sites More sharing options...
Andyuk911 Posted January 3, 2007 Report Share Posted January 3, 2007 Anything that can done with wind noise on an RS4 ... I hit the recycle button and that shuts it up And no comments about go slower Link to comment Share on other sites More sharing options...
TDiAvant Posted January 3, 2007 Report Share Posted January 3, 2007 I've got the same issue on the S4 Link to comment Share on other sites More sharing options...
SamD Posted January 3, 2007 Report Share Posted January 3, 2007 Yup me too, it is hella noisy. Switching off the a/c and opening the window is quieter Link to comment Share on other sites More sharing options...
jwo Posted January 3, 2007 Report Share Posted January 3, 2007 Night time headlight switch illumination (switch replaced twice now) Temperature gauge going nuts - thinks it's a temp sender problem Link to comment Share on other sites More sharing options...
P_G Posted January 3, 2007 Report Share Posted January 3, 2007 No such problems with My S4 a/c, however faults I have are; Replaced auxiliary radiator Broken glove bow hinge Creaking seatbelt annchors (replaced on warranty already and new set creak, also happened on my S3) Reflash of ECU for ignition sequencing Link to comment Share on other sites More sharing options...
master_p35h Posted October 15, 2009 Report Share Posted October 15, 2009 Hi rich... i have purchased a 2001 audi A3 TDI 110, and i have a fault with the performance for example.. when i drive sometimes its fine but sometimes as i do around 70 mph the car feels lumpy and i feel the turbo stops working as it would not do anything above 80 mph when this happens... any suggestions what would this be? and i also have a problem with the driver side window that it keeps winding down and wont close unless i pull it up with hand.... i do not know what causes this? Link to comment Share on other sites More sharing options...
