RedRobin Posted June 13, 2006 Report Share Posted June 13, 2006 I've done a Search but not found any matches. I would be grateful for any advice on how best to maintain a very clean windscreen now that the time of year has brought out the kamikaze bugs. I already regularly use my on board screen washers but they don't shift the bug smears. I guess that a wash by hand may be the only answer. Any particular products to be recommended, please ? Link to comment Share on other sites More sharing options...
johnss8 Posted June 13, 2006 Report Share Posted June 13, 2006 Hi Robin, AutoGlyn glass polish is good but a bit dusty, i would also recommend Sonus glass polish Link to comment Share on other sites More sharing options...
P_G Posted June 13, 2006 Report Share Posted June 13, 2006 Robin, Screenwashers don't work that good on bugs on mine either. A/ slow down so inmpact is less (maybe its just me that has to slow down) B/ AG Fast Glass or if that doesn't work C/ AG Active Insect Remover Both of the latter I use with a kitchen towel to clean the windscreen. Hope this helps! Link to comment Share on other sites More sharing options...
bpsmith Posted June 13, 2006 Report Share Posted June 13, 2006 A good coat or two of glass polish always does it for me. Basically it gives the screen less resistance for the bugs to stick too. I tend to use Newspaper for putting it on though as it works a treat! Just dont use the used newspaper from your fish and chipos though! ;-) Link to comment Share on other sites More sharing options...
NeilB Posted June 13, 2006 Report Share Posted June 13, 2006 Dr OK Wack Screenwash is supposed to be pretty good at removing bugs and muck from the screen. Link to comment Share on other sites More sharing options...
RedRobin Posted June 13, 2006 Author Report Share Posted June 13, 2006 Cheers, guys . Quite a few different products listed to try out. I ain't going to be curtailing any fun for the sake of bugs though! Link to comment Share on other sites More sharing options...
Avus_Bub Posted June 13, 2006 Report Share Posted June 13, 2006 Red, it's got to be Rain-X every time I've used it for years and stopping bugs sticking to the windscreen is just one of it's properties. It's soooo much eaiser to clean the glass with a coat of Rain-X on. BUB Link to comment Share on other sites More sharing options...
RedRobin Posted June 13, 2006 Author Report Share Posted June 13, 2006 Ah - I used my first application of Rain-X (I think - It's in the car) a few days ago (white and creamy substance ? - and no!! it's not sticky!! ). I expected better results but I was "making progress" on some very fast roads. I'll re-apply. Link to comment Share on other sites More sharing options...
dazdot Posted June 13, 2006 Report Share Posted June 13, 2006 [ QUOTE ] Ah - I used my first application of Rain-X (I think - It's in the car) a few days ago (white and creamy substance ?). [/ QUOTE ] No, its a totally clear liquid. eg like water. Link to comment Share on other sites More sharing options...
RedRobin Posted June 13, 2006 Author Report Share Posted June 13, 2006 ....Then it must be another product with "Rain" in the name that I used. Cheers, dazdot . Link to comment Share on other sites More sharing options...
Avus_Bub Posted June 13, 2006 Report Share Posted June 13, 2006 It sounds like you've used the Rain-X glass cleaner, that's white IIRC. The water repellent is clear and has a very high solvent content. You clean the glass, apply the Rain-X with paper towel, work it in well, allow to dry to a haze then splash the glass with water and buff up with a clean paper towel. The glass will be crystal clear. It's top stuff, at speeds of 30mph or more you can get away without using the wipers. On the motorway you sometimes don't even notice that it's raining BUB Link to comment Share on other sites More sharing options...
RedRobin Posted June 13, 2006 Author Report Share Posted June 13, 2006 Cheers, BUB . I'll check out what I've got when I take the car out later. Link to comment Share on other sites More sharing options...
Avus_Bub Posted June 13, 2006 Report Share Posted June 13, 2006 Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted June 13, 2006 Report Share Posted June 13, 2006 Rain-X definitely for me - nothing worse that taking a clean car out for a razz and coming back to find 2 or 3 wasps on the screen in a semi transparent resin like state. All is easily wiped off with rain x applied. I only reapply rain x every 4 weeks too. Seems to last ages. Link to comment Share on other sites More sharing options...
JonnyGTi Posted June 13, 2006 Report Share Posted June 13, 2006 [ QUOTE ] Rain-X definitely for me [/ QUOTE ] Rain-X for me too. Been using it for over 20 years and would'nt use anything else. Passengers are amazed when its raining and I'm travelling at speed (you have to have used it to see this but basically it's like a teflon effect, and the rain just streaks off your windscreen....you don't actually need to use your wipers at speed ) I keep well stocked up when I find some Link to comment Share on other sites More sharing options...
Maxyboy Posted June 14, 2006 Report Share Posted June 14, 2006 [ QUOTE ] [ QUOTE ] Rain-X definitely for me [/ QUOTE ] Rain-X for me too. Been using it for over 20 years and would'nt use anything else. Passengers are amazed when its raining and I'm travelling at speed (you have to have used it to see this but basically it's like a teflon effect, and the rain just streaks off your windscreen....you don't actually need to use your wipers at speed ) I keep well stocked up when I find some [/ QUOTE ]its inn plentyful supply in every halfords i've been in Link to comment Share on other sites More sharing options...
cw955 Posted June 14, 2006 Report Share Posted June 14, 2006 Holts Mixra - sprays on as a foam leave it a few seconds and then use the washers gets rid of bugs grease etc. Used it for years and best thing if in a hurry just to get screen clean. Otherwise either Autoglym fast glass or Meguiars NXT Generation Glass Cleaner. Link to comment Share on other sites More sharing options...
Phil330 Posted June 15, 2006 Report Share Posted June 15, 2006 another rain x fan here! Link to comment Share on other sites More sharing options...
ksteed Posted June 15, 2006 Report Share Posted June 15, 2006 Gold class bug remover, works for me Link to comment Share on other sites More sharing options...
skifly Posted June 16, 2006 Report Share Posted June 16, 2006 so - anyone used this stuff with the rain sensitive wipers on a golfy? Thinking it might be the next purchase... Link to comment Share on other sites More sharing options...
dazdot Posted June 16, 2006 Report Share Posted June 16, 2006 [ QUOTE ] so - anyone used this stuff with the rain sensitive wipers on a golfy? [/ QUOTE ] If you mean Rain X, then yes. It is brilliant stuff, doesn't interfere with the sensitivity of the wipers at all. If it did then i would just miss applying it to the part of the screen where the sensor is. Link to comment Share on other sites More sharing options...
RedRobin Posted June 16, 2006 Author Report Share Posted June 16, 2006 Having now tried both Holts foam and Rain-X, the winner by a mile is Meguiar's NXT Generation Glass Cleaner! Absolute magic! Like all Meg's products. Link to comment Share on other sites More sharing options...
JonnyGTi Posted June 17, 2006 Report Share Posted June 17, 2006 [ QUOTE ] I would be grateful for any advice on how best to maintain a very clean windscreen now that the time of year has brought out the kamikaze bugs. [/ QUOTE ] RR - are you comparing like with like here ? Rain-X is'nt supposed to be a cleaner, it's a rain repellant, ie more like a sealant.....which is what your first post was asking for. I would have thought you could still use Rain X after cleaning your screen with the Megs Link to comment Share on other sites More sharing options...
RedRobin Posted June 17, 2006 Author Report Share Posted June 17, 2006 Yes, I was probably slightly confused but carrying a spray bottle of Meg's plus their Micro cloths works magic to keep my screen clean. I'm not sure I need Rain-X cos the GTI screen is already OEM sealed. Link to comment Share on other sites More sharing options...
petsy Posted June 17, 2006 Report Share Posted June 17, 2006 [ QUOTE ] I'm not sure I need Rain-X cos the GTI screen is already OEM sealed [/ QUOTE ] hmm, I'm not sure I follow you here Red! Link to comment Share on other sites More sharing options...
