Exhaust Vacuum Pipe
nicks3
Has anyone disconnected this pipe from the rear tailpipe yet and if so what were the results? I have looked at it and it doesn't seem to be the normal pull off rubber pipe so am loathe to force it off as I'm not sure if it would go back on easily!
The pipe makes the exhaust quieter at idle and low speed but if you've ever given the car full throttle, thats when the solenoid flapper, that the vacuum pipe opens and closes, is fully open - in other words you have probably heard the difference already.
I never did this mod but from reading other how to's, you need to bung the hose up with something and cable tie it out of harms way to prevent any emissions warning lights.
I'm still trying to get my head around all this exhaust thing so please excuse me for sounding stupid.
I really don't like the exhaust drone on the Mk5 R32 between 1800 and 2200rpm and need to solve that. Under throttle noise is fun but tiresome on a long journey.
So, does this flapper mod quieten the exhaust noise? Does it cure the low rev drone? Would I be better off going for a miltec which (I think) does away with the flapper anyway?
Does anyone have a diagram of the arrangement? Pipe sizes? Could hook up a switch inside the car to block/unblock the line... volume on/off switch grin.gif
You could hook up a switch, but the flap inside the exhaust is mechanically controlled, based on the amount of vacuum created - as the vacuum increases, the flap opens, allowing the exhuast gases to take a quicker route through the back box.
Because it's mechanical, you would probably need to install a solenoid and hook this up to the switch.
You should never think that Ian - that's what Tyresmoke is all about - people sharing their experiences and (hopefully) helping each other out 169144-ok.gif
The drone is common on the Mk4 R32 as well. The flapper mod actually makes the exhaust sound louder - it works in a similar way to the Aston Martin V8 Vantage exhaust system, in that the exhaust takes a quicker route through the exhaust once the car gets beyond 'X' RPM, because emissions noises are checked below this threshold by the Euro testing bods.
Yes, the Milltek is slightly louder from outside the car, but it's actually quieter inside the car - this is beacuse Milltek silencers are built differently and the gases take a more efficient route through the silencer, rather than bouncing around inside the rear box, which is what gives the resonating sound.
HTH
Nicks3, Unfortunately not. I've done it to my mark4. I seriously cannot explain how easy it is to do it. I did it and I don't have a clue. If you search for flapper on Vwvortex, it should bring something up for a mk5. My understanding is now the car sound exactly the same on start up and to cruise around in but if you put your foot down, its a lot louder. If you don't like it you can always put it back on. Good luck!
