fjfr Posted June 26, 2006 Report Share Posted June 26, 2006 Firstly, I just had a service so has this been done or not? - Audi sent me 3 (3!) reminders about it. Second, can I do it myself, and how do I do it if I can? Cheers guys. Link to comment Share on other sites More sharing options...
Mo-S3 Posted June 26, 2006 Report Share Posted June 26, 2006 Yes you can, just dont let the abs pump become emptied of fluid. I use a pressurised brake bleeder thats runs from the the spare tyre at 20psi and forces the fluid through the system and the air out. There is a procedure to do this along with bleeding the brakes in the correct sequence too. Just depends on your level of knowledge. Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 [ QUOTE ] Just depends on your level of knowledge. [/ QUOTE ] None! I know where the break fluid thing is, but that's it. can I not just use a hand pump to pump the fluid out & then pour new fluid in?? Link to comment Share on other sites More sharing options...
blix Posted June 26, 2006 Report Share Posted June 26, 2006 be careful not to get brakefluid on the paintwork or it will take all the dirt off Link to comment Share on other sites More sharing options...
Mo-S3 Posted June 26, 2006 Report Share Posted June 26, 2006 [ QUOTE ] [ QUOTE ] Just depends on your level of knowledge. [/ QUOTE ] None! i think youve just secured your appointment with your dealer! I know where the break fluid thing is, but that's it. can I not just use a hand pump to pump the fluid out & then pour new fluid in?? [/ QUOTE ] Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 but I want to do it for free!! PS. What happens if you don't change the fluid? Link to comment Share on other sites More sharing options...
sitas3 Posted June 26, 2006 Report Share Posted June 26, 2006 I changed mine yesterday - replaced old fluid with dot 5.1 stuff along with refitting my Porsche front brakes - easy enough if you know how but absolutely not for beginners. If you dont change the fluid regularly then the fluid will start to absorb water and you eventually end up with rust/debris in the lines as well as poor braking performance. Fjfr, Leave this to a garage unless you've done it before. Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 Ok Out of intrest, is it best to chip an S3 or upgrade the suspension (assuming that you have money for 1 only?) Link to comment Share on other sites More sharing options...
sitas3 Posted June 26, 2006 Report Share Posted June 26, 2006 Chip. without doubt. Then you'll need better brakes, then suspension etc etc. it won't stop. Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 Yeah, I can't really afford to do more than one (or £1K) but I think that my anti roll brushes are busted, so I thought I'd do suspension.. So no point in suspension without a chip?? PS. Cheers for the advice!! Link to comment Share on other sites More sharing options...
_Tone_ Posted June 26, 2006 Report Share Posted June 26, 2006 Amazing had mine done last week at APS in Brackley (£45) and the difference is amazing - I cant believe the difference actually - must have had a lotta water in there. Tone Link to comment Share on other sites More sharing options...
sitas3 Posted June 26, 2006 Report Share Posted June 26, 2006 [ QUOTE ] So no point in suspension without a chip?? [/ QUOTE ] depends on what you want out of the car. Suspension won't really make the car go faster but will make it more fun to drive unless you constantly hoon around tracks (where you'll get most benefit from suspension upgrades IMO). I plan to take my car on the track and am looking into refitting my old coilovers from a previous S3. Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 It's pretty fast as it is.. better handeling would be nice. I mean the trial chip I had was awesome, don't get me wrong, but it felt like too much for the stock breaks & suspension so if I got a chip I'd end up with that. A better handeling car would be pretty cool, quicker through corners & the like. What suspension mods are best do you think? (I'm looking to spend under £500 if it's poss as have to include insurance, which for a 20 year old is significant.) Link to comment Share on other sites More sharing options...
Mo-S3 Posted June 26, 2006 Report Share Posted June 26, 2006 You would really need to go for a coilover setup but they are not cheap. With fitting ans insurance its going to take you way over budget. Suggest you go for a good spring setup which will improve your handling vastly. Link to comment Share on other sites More sharing options...
fjfr Posted June 26, 2006 Author Report Share Posted June 26, 2006 So H&R sports springs & R32 anti roll bar setup?? AMD quote about £600 supplied, so what £200 to fit? What % insurance increase do we recon? Bearing in mind that a 10% power upgrade (ECU map) was a %10 increase in premium, allthough a 25% power upgrade was 100% increase in premium. PS. Sorry for hijacking my own thread & all the questions!! Link to comment Share on other sites More sharing options...
